Losing some functions
9
So I'm getting some very strange (and minor) problems with my new Vista x64 machine. I am unable to access some basic things like changing the screen saver, viewing network status, or turning on/off windows firewall. When I click on the buttons to run these things, nothing happens at all. Like I said, its all very minor stuff and my system is very stable.
So I tried opening msconfig to see if a service was turned off. But when I clicked on the program, nothing happened. I've also noticed that now I cannot right click -> properties on some things. So I ran a virus scan (AVG) and it came up totally clean. Now I'm starting to worry.
So I've done a sfc from the command prompt and came up with an unrepairable file:
Cannot repair member file [l:32{16}]"comctl32.dll.mui" of Microsoft.Windows.Common-Controls.Resources, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-us", VersionScope neutral, PublicKeyToken = {l:8 b:6595b64144ccf1df}, Type = [l:10{5}]"win32", TypeName neutral, PublicKey neutral in the store, hash mismatch
2008-07-14 08:31:29, Info CSI 00000275 Hashes for file member \SystemRoot\WinSxS\amd64_microsoft.windows.c..-controls.resources_6595b64144ccf1df_6.0.6001.18000_en-us_2b39bc68206382b3\comctl32.dll.mui do not match actual file [l:32{16}]"comctl32.dll.mui" :
Found: {l:20 b:2+OSRbf83erD1b4qj8P7YLv7vkk=} Expected: {l:20 b:IWf153kMlEJUOV14Wd1PkC0vxJM=}
The really strange part is that I'm running a QX9770 Intel Extreme, not an AMD.
Could someone help me out with what my options are at this point? I've tried system restore but I get an error everytime I try to run it:
"Invalid access to memory location. (0x800703e6)"
My system is very new so a clean install of Vista is an option, but I'd like it to be my last resort.
Any help at all would be appreciated.
Dzomlija
Resistance is Futile
2,213
Location
South Africa
The only thing that comes to mind that can cause these symptoms you describe is a virus of some sort, so I'd suggest uninstalling AVG and using an alternative, like Avast!, which picks up items that AVG does not.
I've just now a few minutes ago removed AVG from a computer that "reported clean", but when I ran Avast!, it picked up several files as infected that AVG never scanned.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
LeeTutor
Vista Expert - MVP
178
Location
Coral Springs, FL
Besides viruses, there are spyware, adware, trojans, all kinds of malware that can cause things like this. I run LavaSoft Ad-Aware, SpyBot Search & Destroy, and SuperAntiSpyware on machines I normally service. All are free and can be found easily under those name by a google search of the internet.
9
I ran Avast but nothing came up in the normal search. I did another deep scan on just the windows folder with scan archives selected. No infections reported but I did get several "Unable to scan: CAB archive is corrupted" in "C:\Windows\SoftwareDistribution\Download\.."
Any other tips?
9
"Properties" is one of the functions I've lost on most things, hard drive included.
I did, however, do a chkdsk from the command line (thank god that still works). I didn't see any errors when I ran it though. I could try running it again and watching it this time.
LeeTutor
Vista Expert - MVP
178
Location
Coral Springs, FL
#8
Or you can look at the results of the last run. The location of the chkdsk log for WinVista:
It is in the Vista Event Viewer. type EVENTVWR.MSC in the search dialog at the bottom of the Start Menu and hit the Enter key, reply to the User Account Control prompt, in the left pane click on Windows Logs, then under that click on Application. Next click on the Source column of the middle pane to sort all items by Source. You will be looking for the Wininit entries in the list. The log may also be under Source = Chkdsk when the disk check is user initiated.
9
#9
Thanks for that tip, Lee. Ok, according to the log, the chkdsk, there are no bad sectors but it did "correct" errors in the Volume Bitmap. Hmmm....?
I consider myself pretty computer savvy, but I'll admit that I'm lost from here on out. More help would be greatly appreciated!
LeeTutor
Vista Expert - MVP
178
Location
Coral Springs, FL
#10
Well, I was able to find this MS Knowledge Base article which tells a little bit about the volume bitmap, but it may not be all that clear:
How to locate and correct disk space problems on NTFS volumes in Windows XP
I assume it applies also to Vista.
quote from that article:
NTFS File System Corruption
In very rare circumstances, the NTFS $MFT or $BITMAP metafiles may become corrupted and result in lost disk space. To identify and fix this issue, run the chkdsk /F command against the volume in question. Toward the end of chkdsk process, you receive the following message if the $BITMAP metafile needs to be adjusted:
Correcting errors in the master file table's (MFT) BITMAP attribute. CHKDSK discovered free space marked as allocated in the volume bitmap. Windows has made corrections to the file system.
9
#11
latest chkdsk reports no problems. Guess it fixed it the first time. :p
The problem, however, is still present. I'm going to run another deep virus scan tonight, but beyond that I'm out of ideas.
johngalt
Antidisestablishmentarian
3,921
Location
3rd Rock
#12
BTW - AMD64 is simply the 64bit OS specifications. Intel uses the EM64T specifications for its CPUs whereas AMD uses (obviously) AMD64 - but for all intents and purposes All Intel 64bit CPUs will run code optimized for the AMD64 specification.
So, that is not indicating the *CPU* you have but rather the *OS* you have.
  • Show second system?
    Yes
    Operating System
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
9
#13
Ok, thanks for that info. I was thinking that something really odd was happening.
So I've decided that I'm going to reinstall Vista. Any tips for helping that go smoothly? I've only had the system for 2 weeks, so I'll probably just format the drive and reinstall everything. This will be my first OS install (I don't know how I've managed to avoid it all this time...)
