Low Memory?? All gone at once??
N
nmulder33
I'm a complete dummy when it comes to computers so I hope someone can
help me with this.
I bought my Acer laptop with Vista on it about two years back. The C
drive is the drive that hold all my programs, the D drive is for extra
backup. Yesterday my laptop was showing me an error saying I'm low on
memory. I thought that to be odd as I haven't really installed anything.
So I uninstalled programs or software that I didn't need or used. Today
no matter what I uninstall, and that has been quite a bit, the error
keeps popping up saying that I have no memory left. Then it showed me I
had 18 MB left and I went back to work. Within a short period of time,
I suddenly had no memory left.
Can someone tell me why this is happening?? I make my living on my
laptop and I have no clue what is going on!
nmulder33
nmulder33's Profile: http://forums.techarena.in/members/169115.htm
View this thread: http://forums.techarena.in/windows-vista-performance/1287888.htm
P
peter
You need to post the exact error message as well as specs of your system
We suspect you mean Hard drive space.
Since most Laptops only have one HD we also suspect that
C and D are partitions on same Hard drive. Using a partition
on the same HD as your Main Partition is on is not a good backup
plan. When the HD dies your backups will die with it. Most use
an external HD device for backup.
So the error message might refer to your D partition being full of backups.
If you right click the C and then the D partitions under explorer and then
properties
you will see a graphical representation of your Partitions(?) and which one is
almost full.
please do post back
peter
If you find a posting or message from me offensive,inappropriate
or disruptive,please ignore it.
If you dont know how to ignore a posting complain
to me and I will be only too happy to demonstrate :-)
"nmulder33" <nmulder33.440ura@newsgroup> wrote in message
news:nmulder33.440ura@newsgroup
> help me with this.
> nmulder33
> View this thread:
197
Location
FLORIDA
...You are backing up your files to the recovery partition. The recovery partition is something you don't want to mess with. I'll post more information when I am able to, but basically the D Drive is the recovery drive on an ACER System. Backups, by default, see the recovery partition as a seperate hard-drive when in fact it is actually a "part" of the single hard-drive in your system. Uninstalling programs won't help you, because the programs are on the C Drive. You need to work on the D Drive!!!! BUT DO NOT DELETE ANYTHING IN THAT DRIVE WITHOUT CONSULTING US FIRST IF YOU DO DELETE SOMETHING IN THAT PARTITION YOU COULD MUCK UP YOUR RECOVERY AND BE UNABLE TO REINSTALL WINDOWS IF IT IS NEEDED!!
I want you to go to Start>>Computer>>Recovery "D" Drive">>Take a screenshot of it by using PrintSC and pasting it in paint. Then upload it to Imageshack or a similar service and post the picture here..
PLEASE DO NOT DELETE ANYTHING BEFORE CONSULTING US!!!
    Self-Built
    AMD PHENOM X4 9600 BE 2.3GHZ @ 2.46GHZ
    TA790GX 128M AM2+
    8GB OCZ PC6400 800MHZ DDR2 RAM
    NVIDIA GTS 250 1GB VRAM
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    MS WIRELESS DESKTOP 3000
    6MB/s
    Main Machine. Just upgraded my RAM to 8GB. Next task will be to get a new processor for this machine ( 9650 was for my secondary machine )
P
peter
On my Acer Laptop the D drive is the Data drive
It was set up that way by the original installation.
There is 1 HD with 2 Partitions.. C and D
the Recovery Partition does not show under Explorer only under Admin
Tools/etc/etc
peter
"Timmah" <guest@newsgroup-email.com> wrote in message
news:d83c31962af1b6dfc4ed0701981e52e4@newsgroup-gateway.com...
> Timmah
> If I helped you, No need to thank me, just give me some + Rep :)
CrucialHoax
Action is Knowledge
1,033
More than likely whats happening is that C: drive doesn't have enough room to do the auto back-up anymore. Either that, or your putting info on the D: partition like stated above.
On your desktop, hold the windows key and press R > the run box will open > type cleanmgr > hit enter > there will be an option or a tab to clean up old back-ups for system recovery and keep only the most recent. Use that option.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
