Making html tables
A
I need to generate a html table associated with the error events that is
recorded in the events log. I need to make 2 columns; first the app name and
the second number of errors. I use the following code, but get more entries
than i need. Also how do i go about putting colours on the headings and make
it a neater table. $a=Get-EventLog application | select entrytype,source |
where {$_.entrytype -eq "Error"} | Group-Object source | convertto-html $a >
error.html
Cheers
T
Tao Ma
Hi Arda,
Try:
Get-EventLog application -EntryType Error | Sort-Object Source |
Group-Object Source | ConvertTo-Html Name, Count > a.html
Tao Ma
"Arda" <Arda@xxxxxx> дÈëÏûÏ¢ÐÂÎÅ:ED7726DB-D23B-4698-9AB9-568967A227F5@xxxxxx
> and
> entries
> make
> $a >
> error.html
> Cheers
A
Thank you for the quick reply Tao Ma
I tried it but, got an error about a parameter not being found how ever i
edited your code slightly and got it to work. How would i go about putting in
some color any ideas?
This is the code i used:
Get-EventLog application |select entrytype, source | Sort-Object error |
"Tao Ma" wrote:
> Hi Arda,
> Try:
> Tao Ma
> "Arda" <Arda@xxxxxx> ôÈëÃûâÃÂÎÅ:ED7726DB-D23B-4698-9AB9-568967A227F5@xxxxxx
> > and
> > entries
> > make
> > $a >
> > error.html
> > Cheers
T
Tao Ma
Hi Arda,
I can use regular expression to insert some attributes into html tags. But
it is ugly...Others may give some good ideas later.
Sorry I totally forgot that I am using PowerShell V2 CTP2. So I can use
'EntryType' parameter in my previous code. I modify my code, you can try:
Get-EventLog application | ? { $_.EntryType -eq 'Error' } | Sort-Object
Source | Group-Object Source | ConvertTo-Html Name, Count
I think my code is faster than yours.
Tao Ma
"Arda" <Arda@xxxxxx> дÈëÏûÏ¢ÐÂÎÅ:C6C12B2C-65BE-4068-AE65-0BF101D44656@xxxxxx
> in
> "Tao Ma" wrote:
>> Hi Arda,
>> Try:
>> Tao Ma
>> "Arda" <Arda@xxxxxx> D¡ä¨¨????¡éD???:ED7726DB-D23B-4698-9AB9-568967A227F5@xxxxxx
>> > name
>> > and
>> > entries
>> > make
>> > entrytype,source
>> > $a >
>> > error.html
>> > Cheers
T
Tristan
Here is a link to tag insertion such as Tao Ma refered to below:
http://www.microsoft.com/technet/scriptcenter/resources/pstips/jan08/pstip0104.mspx
Regards,
Tristan
"Tao Ma" wrote:
> Hi Arda,
> Tao Ma
> "Arda" <Arda@xxxxxx> ôÈëÃûâÃÂÎÅ:C6C12B2C-65BE-4068-AE65-0BF101D44656@xxxxxx
> > in
> > "Tao Ma" wrote:
> >> Hi Arda,
> >> Try:
> >> Tao Ma
> >> > name
> >> > and
> >> > entries
> >> > make
> >> > entrytype,source
> >> > $a >
> >> > error.html
> >> > Cheers
F
Flowering Weeds
> putting in
The Windows data parser,
Log Parser, 2.2 will also
do all this (in any Windows
language or Windows tool -
like the Windows automation
tool - Windows PowerShell)!
Start with this information:
PS> LogParser.exe -h -i:evt
Input format: EVT (Windows Event Log)
Parses the Windows Event Log
And
PS> LogParser.exe -h -o:tpl
Output format: TPL (FileTemplate Output Format)
Formats the output following a user-specified template
With the TPL (FileTemplate Output Format)
one can use any html element or whatever
type of file template output format that one
wants to define and use.
Remember, with Log Parser one can
send the output to files, a SQL table
within a SQL data base, a data grid or
even chart the output or to where ever
(when one "creates" a newer output way)!
Notice: IIS does not need to be running
or installed in order to use Log Parser
for either data parsing or chart making.
Search the Internet
(and this newsgroup)
for usage of:
Microsoft's Log Parser
command line usage,
or fully script enabled
either in COM or .NET
(from the IIS group)
Just one of many examples of the
automation tool, PowerShell automating
the Windows data parsing tool, Log
Parser.
A
Thanks Tristan, now that i have color I'm back at square one. The only code
that kind of works is this $a = "<style>"
$a = $a + "TABLE{border-width: 0px;border-style: solid;border-color:
black;border-collapse: collapse;}"
$a = $a + "TH{border-width: 0px;padding: 0px;border-style:
solid;border-color: black;background-color:Blue:}"
$a = $a + "TD{border-width: 0px;padding: 0px;border-style:
solid;border-color: black;background-color:White}"
$a = $a + "</style>"
Group-Object Source | ConvertTo-Html -head $a -Body "Error List" | Out-File
a.html
I just need to get rid of Values and Group, and just have Name and Count on
my html page. Ive been at it for hours and its realy bugging me lol if anyone
can help that will be awesome. Thanks for all the contribution so far, really
appriciate it.
Cheers guys
"Tristan" wrote:
> Hi,
> Regards,
> Tristan
> "Tao Ma" wrote:
> > Hi Arda,
> > Tao Ma
> > > in
> > > "Tao Ma" wrote:
> > >> Hi Arda,
> > >> Try:
> > >> Tao Ma
> > >> > name
> > >> > and
> > >> > entries
> > >> > make
> > >> > entrytype,source
> > >> > $a >
> > >> > error.html
> > >> > Cheers
S
Shay Levi
#8
Here's another option:
$head= @"
<script language="JavaScript">
window.onload=function(){
var TRs = document.getElementsByTagName("TR");
for (i=1; i <= TRs.length ; i++){
if (i % 2 == 1){
TRs.style.backgroundColor = "lightblue";
} else {
TRs.style.backgroundColor = "yellow";
</script>
<style>
BODY{background-color:white;}
TABLE{border-width: 3px;border-style: solid; border-color:white;border-collapse:
collapse;}
TH{border-width: 3px;padding: 2px;border-style: solid;border-color: white;background-color:yellow}
</style>
Get-EventLog application | where {$_.entrytype -eq "Error"} | group Source
-NoElement | select name,count | sort count -desc | convertto-html -head
$head -body "<H2>Error List</H2>" | Out-File a.html
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
> code
> error |
> Out-File
> a.html
> Count on
> anyone
> really
> appriciate it.
> Cheers guys
> "Tristan" wrote:
>> Hi,
>> pstip0104.mspx
>> Regards,
>> Tristan
>> "Tao Ma" wrote:
>>> Hi Arda,
>>> tags. But it is ugly...Others may give some good ideas later.
>>> use 'EntryType' parameter in my previous code. I modify my code, you
>>> can try: Get-EventLog application | ? { $_.EntryType -eq 'Error' } |
>>> Sort-Object Source | Group-Object Source | ConvertTo-Html Name,
>>> Count
>>> Tao Ma
>>>> ever i
>>>> putting
>>>> in
>>>> error |
>>>> "Tao Ma" wrote:
>>>>> Hi Arda,
>>>>> Try:
>>>>> Tao Ma
>>>>>> that is
>>>>>> app
>>>>>> name
>>>>>> and
>>>>>> more
>>>>>> entries
>>>>>> headings and
>>>>>> make
>>>>>> entrytype,source
>>>>>> convertto-html
>>>>>> $a >
>>>>>> error.html
>>>>>> Cheers
