Manual Setup Website - http://192.168.2.1/
B
Ben Ramsay
I cant seem to access the belkin manual setup website, I have tried and
tried to get it and i am about to thow my router on the road and go back to
a Lan network, at least I could get that to work. Anyway my system specs are
as follows :
Windows Vista Home Basic OEM (NEC)
CURRENT NETWORK - LAN
WIRELESS DEVICE TYPE - Belkin Wirless Router 802.11g
SYSTEM TYPE - NEC L1040 Desktop
Any help would be great.
M
Malke
> to a Lan network, at least I could get that to work. Anyway my system
> specs are as follows :
You haven't told us what you tried and what happens when you do. Error
messages (exact text)?
Generally, have the computer attached to the Belkin with an ethernet
cable. Open a browser. If you have difficulties with IE, install Firefox
and use it instead. In the browser's addressbar, type:
http://192.168.2.1 [enter]
If the above doesn't work, try only typing the IP address without the
http://.
This should bring you to the router's login screen. Enter the default
user/password (refer to the manual) and go into the configuration utility.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
B
Ben Ramsay
I can't seem to access this page, I have tried it wi and without the router
with no luck. It keeps showing a 'this page can not be displayed. I have
even tried to access it via my laptop with the same result.
M
Malke
> router with no luck. It keeps showing a 'this page can not be displayed.
> I have even tried to access it via my laptop with the same result.
I don't know what "tried it with and without the router" means. How can
you configure a router without the router? Possibly the best solution is
for you to call Belkin tech support or have a knowledgeable friend
(someone who is really knowledgeable and not just saying s/he is) come
over to help you. Or have a local computer professional come over - not
someone from BigComputerStore/GeekSquad. I just can't make out what you
are or aren't doing from what you're writing.
Sorry that I was unable to help you.
Malke
"Don't Panic!"
