manually uninstall a program
S
stickleback
When I try to upgrade or uninstall acrobat 9.2 I receive the following error:
"The installation source for this product is not available. Verify that the
source exists and that you can access it." I've trolled around different
postings and not found anything particularly useful. Can anyone suggest how
I can manually uninstall acrobat? My OS is Vista Business.
thanks.
Chase
americano
Have you tried un-installing it through Add/Remove Programs in the Control Panel?
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
Æ
Ǝиçεl
Did you ask here ?
http://www.adobe.com/support/
> thanks.
Æ
Ǝиçεl
Did you ask here ?
or
Try to remove it with Revo Uninstaller (Free version), then run CCleaner's
registry cleaner.
<http://www.revouninstaller.com/>
Use the REVO uninstaller (fourth/last option). That way you are
certain to scrap all the registry entries -
Also, try in Tools -> Optimization -. Junk Files Cleaner – Scan -(give it
some time)- Delete
Also, Tools -> Tracks Cleaner, for
Browser Cleaner
Microsoft Office Cleaner
Windows Cleaner
Evidence Remover
Unrecoverable Remover
<http://www.ccleaner.com>
Note, uncheck Yahoos Toolbar
Download the basic version via
<http://www.ccleaner.com/download/builds.aspx>
The basic version does not contain the disgusted Toolbar
Ǝиçεl
> thanks.
S
stickleback
Problem solved: I used the windows installer cleanup utility and then
reinstalled the program.
cheers!
> thanks.
