Map network drive
S
SandyJ
Using Vista Business, I'm unable to map a drive on our LAN. The computer sees
the network server and shares, but when I try to map a share, I get a dialog
box requesting username and password. After completing that, I get a second
box showing server/user then a blank for password. When I fill that out and
enter, I get an error message Logon unsuccessful: Windows is unable to log
you on. Be sure that your username and password are correct.
It's very frustrating because I did a clean reinstall from XP.
K
Kerry Brown
"SandyJ" <SandyJ@xxxxxx> wrote in message
news:CC727E3A-3339-4A98-9411-1791CE0047A4@xxxxxx
> sees
> dialog
> second
> and
Are you in an Active Directory domain? Was the Vista computer properly
joined to the domain?
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca/phpBB2/
S
SandyJ
Thank you, Kerry, but we don't use Active Directory. I was able to find the
solution here: http://www.vistax64.com/tutorials/83931-workgroup-password.html
> > sees
> > dialog
> > second
> > and
> Kerry Brown
K
Kerry Brown
You're welcome. Glad to hear you got it solved.
Kerry Brown
news:0C354CC7-CC3F-470F-BC40-ADF5BB80E309@xxxxxx
> the
> solution here:
>> > computer
>> > sees
>> > dialog
>> > second
>> > and
>> > log
>> Kerry Brown
