Media center wont burn recorded tv to video disc
rmths
When i try to burn a disc from recorded tv list in media center i am askedto select recording and check box
i am unable to check box
on clicking next i can get one of two messages
BURN FAILURE [even though i have not progressed far enough to activate BURN button]
UNSUPPORTED FILE TYPE
Hope this makes sense
Can anyone help?
stoneys-nutz
Gamerholic
Hello rmths,
Found this, i am not into burning discs but this may point you in the right direction.
Hope it helps. Good luck and post your results, thanks.
In Media Center, you can only create a video DVD by using a recorded TV show when the broadcast type matches the region that you have selected in Media Center.
Also have you looked at your codec pack ?.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
