media player will not play vob file
B
Burner
I have family movies saved as vob files on my hard drive. I previously used
media player on an xp computer and they played fine. I recently bought a new
vista computer and copied the vob files to my hard drive. When I try to play
them with Media Player 11, it just shows blank - nothing happens. I tried
adding new codecs but still nothing. If I put a home movie that is on dvd in
the optical drive (contains the same vob file), it will play. How do I get
Media Player to play vob files from my hard drive?
A
Adam Albright
On Thu, 9 Aug 2007 07:48:01 -0700, Burner
Only the Home Premium and Ultimate versions of Vista come with an
included MPEG-2 encoder/decoder. What version do you have?
If neither of those then you need a third party DVD player.
B
Burner
I have Vista Home Premium.
C
Cal Bear '66
Change the extension to .mpg and see if that works.
I Bleed Blue and Gold
GO BEARS!
"Burner" <Burner@discussions.microsoft.com> wrote in message
news:B9F029F5-E88B-4BC5-87F7-E3A2FBE43511@microsoft.com...
A
Adam Albright
On Thu, 9 Aug 2007 09:30:06 -0700, Burner
Well I have the business version of Vista. While Windows Media Player
won't directly play a DVD, it will play VOB files if you open the TS
folder and click on the individual files.
That you can't suggests something has messed up Media Player. Just
looking at it wrong will cause it to malfunction.
J
John Lee Brown
Try downloading VLC for windows at http://www.videolan.org/vlc/ it works on
my wife's Vista Basic machine.
"Adam Albright" <AA@ABC.net> wrote in message
news:rcjmb3p7jh7rrn38v6a75ooieqfefp643i@4ax.com...
>>> >used
>>> >a new
>>> >to play
>>> >tried
>>> >dvd in
>>> >get
B
Burner
I changed the extension to .mpg. It worked a little - Media Player opened
the video and played it for a minute or so, then skipped a little, then
skipped a lot and stopped. Any idea what to do now to get it to work with
Media Player 11?
> GO BEARS!
B
Burner
#8
Thanks. I downloaded VLC and it plays the vob file and the mpg file very
well. But, I would still like to play it with Media Player so I can use the
Windows Media Center. Any other ideas?
> >>> >used
> >>> >a new
> >>> >to play
> >>> >tried
> >>> >dvd in
> >>> >get
