Medion TV-Tunercard doesn't work with Media Center
D
deeppurple1998
My Medion TV-Tunercard ( Medion TV-Tuner 7134 MK2/3 + Medion (7134) WDM
Video Capture ) doesn't work with Media Center.
Thanks in advance for a solution !
deeppurple1998
P
Peter M
MCE requires a hardware mpeg2 encoder. If your card use a software enconder
it will never work under MCE.
Somedays I'm the Snark, others the Boojum!
"deeppurple1998" <deeppurple1998@gmail.com> wrote in message
news:15C4B4B5-0252-474A-8AA5-2AA924E8708E@microsoft.com...
> deeppurple1998
C
Christopher L. Estep
"Peter M" <pmcneil1@cogeco.ca> wrote in message
news:u1Ei6sGrGHA.1552@TK2MSFTNGP02.phx.gbl...
> enconder it will never work under MCE.
Flatly untrue.
The ATI HDTV Wonder (and ATI All-In-Wonder series) all use software MPEG2
encoding, and all are supported in MCE 2005 (additionally, the HDTV Wonder
is supported *standalone* since Vista 5456). MCE 2002/2004 *did* require
hardware MPEG-2 support, but that isn't true of either MCE 2005 *or* Vista.
You have it backwords
All HDTV tuner cards need no encoder since the digital ATSC broadcasts are
already encoded.
ATI introduced a software encoder with MCE 2004 for its AIW N TSC tuner
cards which was approved by Microsoft as long as a HT or dual CPU system was
used due to the high CPU utilization required for software encoding.
With the introduction of multiple tuner support by MS with the introduction
of MCE2005 MS would no longer approved software encoders in order for a
vendor to qualify their cards for the MCE2005 logo program. ATI of course
supports this implementation on their own.
In early summer of 2005 ATI upgraded the software encoder that worked with
MCE 2004 so it would work with MCE 2005 and provided it to AIW card
purcharsers as part of the ATI MMC media center application. AFAIK ATI has
not upgraded this software encoder again for VISTA so that it can be used
with AIW cards or with the NTSC tuner on the HDTV tuner card.
Since Vista does not require an NTSC tuner card in order for a ATSC tuner
card to be used the ATSC tuner side of the HDTV wonder should work fine with
vista since as I stated before all ATSC video is already encoded so no
encoding hardware or software is required.
"Christopher L. Estep" <pghammer21@comcast.net> wrote in message
news:D84112FA-4508-4928-9FD3-3BE70AACDCDA@microsoft.com...
> Flatly untrue.
> Vista.
T
> deeppurple1998
Hello deeppurple1998,
I managed to get Vista MCE working on my Medion 8800 with exactly the same
Tuner as yours. You have to install the MCE Software decoder, from Cyberlink,
and then everything works fine. Just google for MCE Software decoder and
Medion and you'll find what you're looking for.
