Memory Diagnostic Fails - Computer shut's down
R
Rus787
I try to run the Memory Diagnostic for Home Premium and the computer shuts
down at about 30% on the first pass. Is there anything else other than RAM
problems that could cause this situation?
M
mikeyhsd
HEAT.
mikeyhsd@comcast.net
"Rus787" <Rus787@discussions.microsoft.com> wrote in message news:CAF65BF3-00F5-4C66-B096-4062A88FF77A@microsoft.com...
M
Malke
Sure, lots of things. Heat, bad power supply, bad motherboard, bad
processor...
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
D
Dustin Harper
Heat can cause it, but you're not running the CPU at 100%, just running
memory diagnostics. It could be a bad motherboard (northbridge, check to see
if it has a fan or if it's really hot to the touch), power supply...
Dustin Harper
dharper@vistarip.com
http://www.vistarip.com
> RAM
C
cquirke (MVP Windows shell/user)
On Sun, 24 Jun 2007 09:22:47 -0700, "Dustin Harper"
>memory diagnostics.
Actually, you are - they aren't padded by a power-saving "do nothing"
idle state. You may not be using all of the CPU, but you certainly
are using the CPU 100% of the time.
You won't be fully loading the PSU either, or stretching the graphixcs
chipset, so problems may still arise from these when you start using
HDs (PSU) and 3D or "advanced" graphics (SVGA and PSU).
The most accurate diagnostic instrument
in medicine is the Retrospectoscope
