Memory Management blue screen error
Brandonlee
For the past 4 months, I've been repeatedly getting a blue screen telling me I have a Memory Management error after playing games on my computer for random amounts of time and rarely when I watch videos. Unfortunately after I get the blue screen, it restarts my computer so I haven't been able to see if I've had a major memory usage spike, but I have used the windows memory diagnostics to test my ram and it says no problems were detected. I've also tried to simply format my hard drive and reinstall vista, just in case a virus was causing it, but it didn't fix anything.
I don't understand what caused it since I haven't downloaded or installed any new software or hardware and the first time it happened, I had already been playing a game for a few hours.
I have:
Acer Aspire 4720Z laptop
Intel Pentium dual-core processor T2310
2.50 GB ram
Windows vista home premium 32 bit
Any help into the matter would be greatly appreciated.
D
DL
Have you tweeked the Bios settings?
www.memtest.org have a bootable memory testing utility
"Brandonlee" <[email protected]> wrote in message
news:[email protected]
> fix anything.
> I have:
> 2.50 GB ram
> Brandonlee
C
Curious
Apparently you have Automatically Restart enabled in Advanced System
properties. If yes disable it.
> fix anything.
> I have:
> 2.50 GB ram
> Brandonlee
Brandonlee
The only thing I've done with the bios was change the boot sequence to have my CD Rom as first preference so I could reinstall vista. I've always been afraid to mess with the bios much since I really don't know much about it.
Also, I did have the auto reboot box checked. It's unchecked now so hopefully I can get back to you with the memory info next time it hapens.
C
Curious
What is the configuration of you 2.5GB of RAM?
Vista does not like RAM that does not all operate at the same speed. So
when using DDR2 RAM you should only use a matched set of 1GB RAM to get to
2GB.
I suggest that you consider downgrading to to 2GB.
> much about it.
> hapens.
> Brandonlee
P
Peter Foldes
Brandonlee
Run the memtest as suggested by others. Try not looking for a quick fix . You have a
problem with the memory on your computer
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
> much about it.
> hapens.
> Brandonlee
Brandonlee
That could be the problem then. I have a (DDR2) 2GB RAM I installed myself and a 512 MB RAM from the factory. Because I don't have the other factory 512 RAM card anymore, would it hurt to use the 2GB card and have the second ram slot empty until I can buy another?
2GB.
C
Curious
No it would not hurt and you don't want to install a second memory stick
unless it is exactly the same part number as the first one otherwise you
will not have a matched pair. And even then it may cause a problem since
they were not purchased together.
>> So
>> to
>> 2GB.
> Brandonlee
Brandonlee
I guess that's what the problem was, I removed the older RAM and I haven't gotten any more Memory Management errors. Thanks for the help!
A
Amadeus87
> stick
> you
> since
> This is not true, I have the same issue and my memory sticks are both
> 1gb and out of the same package! different kinds of memory sticks have
> nothing to do with it unless they are different speeds because the
> motherboard can only take certain speeds to spec.
> @ Peter Foldes: I don't think it's faulty memory either. Since I got
> the blue screen with the same Memory_management error just today I
> haven't been able to boot up windows since. When i do try my error is;
> Windows failed to load because a critical system driver is missing, or
> corrupt.
> status: 0xc0000225
> File: /windows/system32/drivers/Wdf01000.sys
Amadeus87
Amadeus87's Profile: http://forums.techarena.in/members/226700.htm
View this thread: http://forums.techarena.in/vista-setup-install/1203579.htm
