Microsoft Flight Simulator X Narrator Mission Sound Problems
A
Andy1994
Hi everyone, Since I upgraded my computer to Windows Vista and installed
Flight Simulator X, there has been no sound of the narrator at all in the
missions. Also, there is sometimes no sound at different view angles of the
aircraft. There was no problems like this when I had it on Windows XP. I
would greatly appreciate it if someone out there could give me a solution
to this as I have no idea what to do. Thanks so much, Andrew
J
"Andy1994" <Andy1994@xxxxxx> wrote in message
news:CF944C13-A6E0-4745-9EEA-22C35BEC9ABF@xxxxxx
> the
FSX put it under Settings/General and not under Sounds. Look there.
There's a check mark to turn it on and which voice to use.
H
h8196288
Hi guys, I too was having this problem and searched the internet for
ours for a solution to no avail.
All I simply did was download the latest drivers from realtek as my
sound card was configured to run 5.1 speakers which I didn't have :S
Once downloaded, make sure that you set your speakers up properly, ie
if you only have 2.0 speakers, then set it up to run in 2.0, not 5.1 as
mine originally did.
Hope this solves some problems.
h8196288
h8196288's Profile: http://forums.techarena.in/member.php?userid=50492
View this thread: http://forums.techarena.in/showthread.php?t=905457
B
briande
It is the same problem as main. I received this error message: "no audio
output device is installed"
Go to http://www.noaudiooutput.com I found my solution there. They have
many suggestions. I think you find there a right solution for your
problem.
briande
briande's Profile: http://forums.techarena.in/members/129823.htm
View this thread: http://forums.techarena.in/windows-vista-games/905457.htm
