Microsoft Transient Multi-Monitor Manager???
J
JethroUK©
I have desktop PC and only one monitor and I can't see why i need to run it
*ever* and yet this task is in my scheduler programmed to run every time
anyone logs on - and it's been running now for 17 hours continuous????
Do i need this task to run?
There seems to be dozens of these 'apparently' unnecessary tasks being
performed - e.g. 'mcupdate' checks for media centre updates (which i never
use) - even if i did a check once per month would be sufficient - but this
is scheduled to run every - single - day
does this explain why i don't have enough processing power left to open an
explorer window in under 20 seconds despite having 4 times the power of my
ol XP machine?
Are there any tasks known to be useless that i can disable? and hopefully
speed up my machine
"JethroUK©" <reply@xxxxxx> wrote in message
news:uV0Rj.127513$Lq5.33108@xxxxxx
> my ol XP machine?
> speed up my machine
You can disable the majority of the tasks in there, without any major
issues. The subfolder in which they're located gives a good indication of
which programs they're connected to. If you don't use multiple monitors or
Media Center, then sure, disable them.
Jon
C
Clear Windows
Hello, can you give us a more detailed list of what we can disable and why..
or do you know of some resource online?
I have tried various configurations of these tasks.. but I would like to
compare with what other people are doing
thanks
"Jon" <Email_Address@xxxxxx> wrote in message
news:OTuOJUJqIHA.3616@xxxxxx
>>it *ever* and yet this task is in my scheduler programmed to run every
>>time anyone logs on - and it's been running now for 17 hours
>>continuous????
>> never use) - even if i did a check once per month would be sufficient -
>> but this is scheduled to run every - single - day
>> an explorer window in under 20 seconds despite having 4 times the power
>> of my ol XP machine?
>> speed up my machine
> Jon
"Clear Windows" <carlferedeck@xxxxxx> wrote in message
news:4815c402@xxxxxx-privat.org...
> why..
> thanks
I don't know of any definitive resource, but see if this MS link helps
Description of the scheduled tasks in Windows Vista
http://support.microsoft.com/kb/939039
AFAIK there are no major issues disabling any of those tasks, and by major
issues I mean Vista not booting - not whether an automatic restore point is
created or not, or whether a calendar reminder works You'll lose a bit of
inbuilt functionality if you disable anything in there, but the question is
how significant that piece of functionality is to you.
In the early days of my using Vista, when I was testing out the new os, I
ran it exclusively within a virtual machine. There speed was a, if not
*the*, primary concern, and one area I experimented with was disabling
nearly all of those tasks - without any major problems.
For example being able to run DirectX applications within a virtual machine
meant that I had little need of Media Center background tasks, BUT when
using it normally installed on a machine I would keep the task the OP
mentioned 'mcupdate' enabled, since it's a useful task that downloads the
'guide' - which I often use and wouldn't want to do without. Tasks like
defragmentation and System Restore I disable in favour of my own
preconfigured tasks- and it's up to you if you want to help MS out with
their next os via the "Customer Experience Improvement Program" or "Windows
Error Reporting" - matter for individual choice, I suppose.
So it would be difficult to give a "one-size-to-fit-all" answer, but
perhaps that helps a bit.
Jon
C
Clear Windows
thanks...
news:ui4mpIWqIHA.3900@xxxxxx
>> why..
>> thanks
> is created or not, or whether a calendar reminder works You'll lose a bit
> of inbuilt functionality if you disable anything in there, but the
> question is how significant that piece of functionality is to you.
> machine meant that I had little need of Media Center background tasks, BUT
> when using it normally installed on a machine I would keep the task the OP
> "Windows Error Reporting" - matter for individual choice, I suppose.
> Jon
