Microsoft Wireless Laser Mouse 5000
I
ilyabyk83
Hi People, very simple question. Maybe I could get an answer to my question that I should had asked when I was buying. This wireless mouse uses two "AA" batteries or rechargeable batteries. Question: What about turning it off for the night or whenever I leave my computer? So that I don’t change them every two-three days. Thank you for your help with such a stupid question.
mansrm81
The mouse should go into a low power mode so it doesn't use that much battery power.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
I
ilyabyk83
Hey. Thanx for your help. After how long and how would I know it did? Just now, didn't touch it for a half hour, I touched it, and the cursor did move on the screen. How long does need to sit there before it goes in "low power mode"? How do I tell if it did or didn't?
mansrm81
Its a built in feature cause it will still have to send a signal to the usb receiver. Also if you have a good set of rechargeables it should last about a month or 2 as my mouse lasts that long.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
I
ilyabyk83
Thanx then!! Do you mind if I mark this "SOLVED" then??
mansrm81
Glad I could help ilyabyk83.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
