Missing Startup Repair Tool
SteveOsl
2
I bought my laptop about a year ago and it had Vista Home Premium pre-installed, it was not supplied with any installation disks. How can I install the Startup Repair Tool without the installation disk, or where do I get it from?
Regards
Steve O
    Intel Pentium Dual Core T2060
    2GB
    Intel GMA 950
    120GB
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Hello Steve O, and welcome to Vista Forums.
This tutorial will show you how to create a Recovery Disc of you your own that can be used to repair Vista. It cannot be used to reinstall Vista though.
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
You should have a recovery partition that will allow you to make a set of Recovery CD/DVDs of your own though that you can use to reinstall Vista with if needed. What is the brand and model of your laptop? I'll post back instructions for how to from the OEMs website.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
SteveOsl
2
Thanks for the reply Shawn.
The laptop is an Acer Aspire 5612ZWLMi. I've got two partitions on the disk; C and D, no recovery partition as such.
Regards
Steve
    2GB
    Intel GMA 950
    120GB
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
Hello Steve, welcome to Vista forums!
I believe if you check into it you'll find that the D: partition is the recovery partition.
Look in the start menu to see if you can find an option to create a set of recovery discs.
You can also return it to the way it was when it was new from the recovery partition.
Keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Ok Steve,
I found this for Acer on how to create a Vista Recovery CD from your D: Recovery Partition. This will only let you reinstall Vista though. You will still need to create the other recovery DVD from the tutorial I posted above to run a startup repair though.
  • Open the Acer eRecovery Management program
  • Click the burn disk button at the bottom
  • Click the create factory default disk button
  • Put a blank DVD in the drive when prompted and follow the remaining on screen instructions
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
