Missing torrent files
Zilius
4
Solved
I recently torrent a file which seems to be missing from my pc. One of the solution proposed by some of the older forum thread includes selecting compatibility files. I'm not sure what they meant by compatibility files? I'm using vista x64 and I checked everywhere but I can't seem to find what they are talking about.
some sources says it might be in the temporary internet folders. my folder properties tell me it has 4gb+ of data in there, which is about the same size as the file I torent, but when I open the folder there seems to be only text files coming up to a couple of mb.
If anybody knows any solution help me out please
106
Location
Philippines
On the desktop press Windows key + F3 Which will bring up the search box. In the search box make sure you select the entire computer to be searched. Then copy and paste the next line I'm going to type in the search field. After that press enter or search
*.torrent
Copy the above line and I hope this helps. Good luck
    Intel Core2 Duo E2200 2.2 GHz
    Emaxx IG31-AVL (AMI 1.1 Bios)
    4.00 GB DDR2-800 MHz Dual Channel Memory
    Inno 3d GeForce 9500 GT 1GB DDR3
    Realtek 6 Channel On Board
    15" Generic Flat Screen Panel
    1024 * 768
    1 Seagate 80GB 7200 RPM SATA
    1 Western Digital My Book Essentials 1TB
    500W
    LGA 775 Compliant Case
    Case Fan (Generic)
    Generic PS/2 Mouse
    Generic PS/2 Keyboard
    1Mbps DL 600Kbps UL
    Altec Lansing 2.1 Sound System
    Nokia 5800 Xpress Music RM -356 v31.0.101
106
Location
Philippines
No go, no sign of it =(
I'm guessing the torrent has been permanently deleted. What's the torrent anyway? If you don't mind me asking. Maybe I can get another copy of it :)
    1024 * 768
    500W
    Case Fan (Generic)
    Generic PS/2 Mouse
    1Mbps DL 600Kbps UL
Zilius
4
Solved, it was in temporary Internet files all along. =(
vista apparently has a lot of safeguards within the TIF, its a long winded step to open it folder by subfolder(have to go through dos to delete some destop hidden file etc etc). However one guy suggest i copy the exact address, and it was there all along, even though searching the whole computer failed to find it.
thanks for your help anyway. have a nice day =)
106
Location
Philippines
Hey, it's nice to hear you have it again. No problem buddy, you too
    1024 * 768
    500W
    Case Fan (Generic)
    Generic PS/2 Mouse
    1Mbps DL 600Kbps UL
R
R. C. White
Hi, Zilius.
The TIF is best managed from inside Internet Explorer. Click Tools |
Internet Options. On the first tab, General, it's under Browsing History in
IE8; I've already forgotten what IE7 called it. But click the Settings
button there. In the next window you should see buttons to Move folder,
View objects and View files. This is where I bail out on you because I
always get lost after this point - except that I did long ago move my TIF to
another volume.
I learned many Windows/IE versions ago that files in the TIF are not
"normal". That "Content.IE5" folder is WEIRD! There are always 4
randomly-named folders and all seem to have mostly identical content.
Trying to find and delete a file in a Command Prompt window gets me into "a
maze of twisty little passages, all alike", to quote the ancient Adventure
game. :>( I try never to go in there!
RC
R. C. White, CPA
San Marcos, TX
rc@newsgroup
Microsoft Windows MVP
Windows Live Mail 2009 (14.0.8089.0726) in Win7 Ultimate x64
"Zilius" <guest@newsgroup-email.com> wrote in message
news:d589f62882e8102ec2f7ff1b431544f4@newsgroup-gateway.com...
Zilius
4
#8
Hi, Zilius.
another volume.
[/QUOTE]
Does moving TIF to another volume changes the attribute of TIF?
I agree about the content.IE5 folder, noticed some totally random data from ages before stored in there as well. However the folder is hidden no matter how I mess with folder options. The only way I found so far to access this file is if you type the full address linking to the IE5 folder, which then miraculously opens up.
R
R. C. White
#9
Hi, Zilius.
No. All it does is keep the TIF from using up disk space on the boot
volume, typically Drive C:. Many users need more room on that drive.
This can be even more helpful for those of us who dual-boot. We can point
IE from each of our OSes to the same folder on the "neutral" drive. (I put
them all into E:\TempInet.) Then check the box in Tools | Internet Options
| Advanced that says to Empty the TIF when the browser is closed. Since we
can't be running two OSes at once, each can use the same TIF without
conflict.
RC
R. C. White, CPA
San Marcos, TX
rc@newsgroup
news:74bac8027406cf0c2c23e9d2882da159@newsgroup-gateway.com...
> R. C. White;1180415 Wrote:
>> Hi, Zilius.
>> History in
>> Settings
>> folder,
>> I
>> TIF to
>> another volume.
>> into "a
>> Adventure
> Zilius
