Missing volume bar
C
coach5inbuff
I just purchased a new computer with Vista on it and when I began using it as
I raised or lowered the volume a volume bar appeared that showed the relative
level of the volume. For no reason, when I adjust the volume the bar no
longer appears. I did not intentionally turn it off and would like it back
on. How do I get the volume bar to reappear?
R
Rick Rogers
Are you referring to one the appears on the screen as a series of bars? Or
the one that is sort of gray with a slider that appears vertically over the
sound icon in the taskbar? The former one is a function of the system that
may not appear if some other program has control over the screen
presentation (for instance, my laptop will show the bars if nothing else is
open, but if I'm running a remote desktop session the bars will not show
when the volume is adjusted).
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"coach5inbuff" <[email protected]> wrote in message
news:[email protected]
>as
> relative
> back
I also want this on my laptop which is an HP Pavilion dv8315nr. I miss it. I
also don't want to have to pay $59.00 for a tech to tell me how to do it.
When I just bought two Hp's running microsoft products. There must be a
simple fix. Why wasn't it included? Howard Page,Seabrook NH
M
mikeyhsd
are you trying to adjust the volume using a key on the keyboard or by clicking on the speaker icon in the tray.
if it is the keyboard then you need an updated driver from hp.
[email protected]
"[email protected]" <[email protected]@discussions.microsoft.com> wrote in message news:[email protected]
Rickw
I just bought a DV2915nr and would love to get rid of that gray bar that pops up in the middle of the screen. I found something in the volume settings that looked like it, but it didn't do the trick. When I went back to it, it was gone completely. Does anyone know how to get rid of that volume bar?
Rickw
I posted a request to learn how to get rid of that bar. What I found below worked, and reversing it might get back the bar for people who want it:
You don’t have to uninstall any software to get rid of the on screen Volume Display.
1. Click the Vista start icon, bottom left.
2. Type RUN in the Start Search box, ENTER.
3. Type MSCONFIG in the OPEN: area, Click OK.
4. Click on Continue if asked.
5. Select the StartUp Tab in the System Configuration menu.
6. Remove the checkmark from the HP Quicktouch On Screen Display item.
7. Click on OK and Restart if required. You are done.
Reverse above procedure to restore to original if desired.
tranks
this worked for me. i hated that gray/black volume display that pops up in the middle of the screen and blocks everything i'm trying to view for what seems like 10 mins. (really about 5-10 secs)
it was also pointless with the small gray/green bar that pops up in the corner too. i like this one and doing the above steps did not effect it.
    HP dv6747nr
    2.0 GHz AMD Athlon 64 X2 Dual-Core Mobile Technology TL-60
    3072 MB
    NVIDIA GeForce Go 7150M
    250 GB (5400 rpm)
    nothing special, just a laptop that still works great after 4 yrs of daily use.
