Model3DGroup behavior
I have 2 identical surfaces, one at -z and other at +z location. They both
have a transparent Material on the front side and a non-transparent
BackMaterial on the other side.
<Model3DGroup>
<AmbientLight ... />
<DirectionalLight .../>
<GeometryModel3D x:Name="Side1">...</GeometryModel3D>
<GeometryModel3D x:Name="Side2">...</GeometryModel3D>
</Model3DGroup>
When I rotate this model group around the y-axis, the behavior appears to be
different depending on the order the GeometryModel3D shows up on the list.
The first one seems to be non-transparent. I can reverse the order and the
other surface become non-transparent. Is this the expected behavior or am I
doing something wrong?
T
TheRHogue
Expected behavior for Version 1 of WPF. You will need to sort the geometries
per render cycle.
I have a simple example of this at http://www.therhogue.com/WinFX -
collageview sample.
> <Model3DGroup>
> </Model3DGroup>
Thanks for the help. This is some heavy lifting. Especially since I'm
making a spinning cube.
> per render cycle.
> collageview sample.
> > <Model3DGroup>
> > </Model3DGroup>
