Modem : communication cable between two
K
kosamui
Under Vista, we installed a modem (communication cable between two PCs) in
order to use a PPP communication on a serial port (speed 115,2KBds). It is ok
under XP but with Vista, the speed of the modem is 19200 bauds and the combo
box is grayed; how can xe change this speed ?
Thank you
merci
J
Jack \(MS, MVP-Networking\)
Hi
Check the setting of the serial port in the computer's BIOS.
BIOS can usually accessed during Boot.
Jack (MS, MVP-Networking).
"kosamui" <[email protected]> wrote in message
news:[email protected]
> Hi,
> ok
> combo
> Thank you
> merci
K
kosamui
Thank you for your answer; I didn't yet verified since the PC is in use; I
tried on a windows 7 platform where the serial port is oK in he BIOS's
computer ; on the configuration of the connection, I saw the hard flow
control is enabled, I needed to disable it, I did it but each time I control
it again, it is enabled again; and so the connection failed with error 777.
regards.
merci
"Jack (MS, MVP-Networking)" wrote:
> Hi
> > Hi,
> > ok
> > combo
> > Thank you
> > merci
