Modify Multiple files' NTFS permission
M
msxcms
In Windows XP, I can select Multiple files and right click them to modify
permissions in Security Tab. But in Vista, I can't see the tab when I select
multiple files and see the Properties. How can I do it like XP?
J
Jimmy Brush
Hello,
I'm not aware of any way to do this exactly like Windows XP.
You can do so using the icacls command-line tool when using an elevated
command prompt.
To open an elevated command prompt:
- Click start
- Type: cmd
- Right-click cmd when it shows up under programs
- Click Run As Administrator
The icacls tool takes a bit of getting used to. Here's an example command
line:
icalcs *.txt /grant Jimmy:(F)
Grants the user Jimmy full control over all text files in the current
directory.
- JB
Windows Vista Support Faq
http://www.jimmah.com/vista/
M
msxcms
In XP, do it like the following media file:
http://shengyu.bmforum.com/personal/ntfs.avi
(XP Professional with HP Desktop)
