Moniter doesnt recogonize Nvidia 9300GE anymore! instead it says "default moniter"!
viperstalkerx
hi, i have a problem. i have a 9300GE pci-e card then i put in a FX5200 into the PCI slot and loaded it up. my main 24" monitor connected to the pci-e didnt load but instead my 19" monitor started up. I couldnt get them both to work so i took out the fx5200 and went back to my 24. Only problem now is that it doesnt work properly. when i right click then click personalize and then click display settings my graphic card isnt listed instead it says "default moniter" on. also my previous windows index score was 4.9 with 9300GE and now it's 1.0
any help or advice would be appreciated. im on windows vista home edition 64 bit
MrNeeds
PC Geek
Re: Moniter doesnt recogonize Nvidia 9300GE anymore! instead it says "default moniter
any chance you can take a screenshot of your display properties? and possibly a screenshot of your device manager under display adaptor?
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
MrNeeds
PC Geek
    16Mb Sky bb
viperstalkerx
so i just download it and then go into remote device and click uninstall drivers? or do i just directly click installing the drivers?
MrNeeds
PC Geek
directly click and install, should be fine
    16Mb Sky bb
viperstalkerx
i get the nvidia setup error
"the nvidia setup program could not locate any drivers that are compatible with your current hardware. setup will not exist."
it then said reinstall with "correct settings" so i hit ok and then it gave me an error saying i was trying to uninstall it with 32 bit drivers when i needed 64 bit
NormCameron
The drivers for 64bit and 32bit are different. Make sure you download the x64 drivers from Nvidea.
Norm
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
viperstalkerx
yeah this was with the x64 one. the one i tried installing was the one on top and it first gave me the ""the nvidia setup program could not locate any drivers that are compatible with your current hardware. setup will not exist." error. then it asked me if i wanted to install it with the "recommended settings" and that 32bit error popped out even though i was using the x64 bit installer mentioned above.
NormCameron
I know this was a problem with earlier vista drivers from Nvidea, but I thought this had been fixed with the latest drivers? Have you tried installing the drivers using "Run as Administrator"
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
