Monitor Way to dark Worked just fine on xp
W
Waffleman
I Just upgraded to vista from xp and everything working fine except that the
display is Just too Dark. I've turned the contrast and brightness up all the
way but the display is still too dark. Please help PS I'm not a programmer
pleas answer the question in English that i can comprehend.
Thx
M
Mick Murphy
Right-click on the empty Desktop> Personalise> change to your heart's content
> Thx
A
Andre Da Costa[ActiveWin]
Have you tried turning off AERO? Following on Micks path, click Themes, then
click in the Themes list box and select Windows Classic and see if thats
better for you. :)
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
"Waffleman" <Waffleman@xxxxxx> wrote in message
news:01958B49-4515-4DC1-9035-A12B9C2C1E14@xxxxxx
>the
> the
> Thx
L
Lang Murphy
>the
> the
> Thx
Vista is using different drivers for your video card and your monitor than
XP. Check for updated drivers for both. The video card is the important one.
Do you know if you were using a generic monitor driver under XP or a model
specific driver? If the former, forget about it. If the latter, you might
want to check to see if Vista is using the model specific driver or just a
generic driver.
Lang
