Mouse interferes with sound
Z
Zachary Turner
Does anyone know why moving the mouse generates sound from my
speaker? It's a slight ringing noise, it has happened to me on every
version of Windows since 2000, probably before that as well, and it's
horribly annoying. It's even worse when I use the mouse to drag a
scrollbar or a window. Since I've never had a windows installation
where this DIDN'T happen, I'm assuming it's a global problem and
others have experienced this as well. If you don't know what I'm
talking about turn the volume on your speakers way up and then move
the mouse around.
If anyone knows how to get rid of this I would really appreciate it.
G
Gary S. Terhune
It's called radio interference and you get rid of it by placing your
speakers *well* away from the PC. I've got a fairly loud static, anyway,
because the base woofer cabinet is practically leaning against my tower. If
I turn my speakers way up, the small battery powered clock that's 6' away
from the desk can be heard tick-tocking. Probably doesn't help that I have
an Army surplus steel desk.
Mine's a wired mouse, currently. Perhaps a wireless mouse would help the
problem. Or perhaps it would be worse.
Gary S. Terhune
MS-MVP Shell/User
http://grystmill.com
"Zachary Turner" <divisortheory@xxxxxx> wrote in message
news:79d7098c-238d-40a9-b780-1b17ab9a41e2@xxxxxx
> the mouse around.
I
Ian D
> the mouse around.
This can be an issue with on-board audio, especially with earlier
motherboards. If you have on-board audio, the best solution is
to get a PCI sound card. This is usually not a problem on recent
motherboards with on-board multi-channel HD audio.
G
Gary S. Terhune
I'll ask you, too. What makes onboard sound different than a PCI card in
this respect?
Gary S. Terhune
MS-MVP Shell/User
"Ian D" <taurus@xxxxxx> wrote in message
news:eSMcy%23uDJHA.3456@xxxxxx
>> the mouse around.
I
Ian D
"Gary S. Terhune" <none> wrote in message
news:u8wAgxwDJHA.4724@xxxxxx
> this respect?
> Gary S. Terhune
> MS-MVP Shell/User
The noise problem with on board sound is only audible at high
amplification settings, and most noticeable when no other sound
is being generated. On board sound codecs rely on the CPU for
processing and are tightly integrated into the motherboard circuitry,
and subjected to electrical noise, especially on the v+ line. A lot of
the noise is generated by changes in processing load caused by
interrupts. Most interrupt noise is high frequency and random,
and blends into the normal backgroung hiss. A moving mouse
generates a stream of repetitive interrupts in the audible range,
the effects of which can be clearly heard when the volume is set
high. It's the mouse generated noise that is the cause of complaints.
The PCI bus is more electrically isolated from CPU activity. Also,
most quality PCI sound cards do their own on card hardware sound
processing, and have additional filtering on the power connections.
G
Gary S. Terhune
Thank you, <s>.
Gary S. Terhune
MS-MVP Shell/User
news:uMqSXo2DJHA.528@xxxxxx
>> this respect?
>> Gary S. Terhune
>> MS-MVP Shell/User
