Mouse pointer goes berserk....
2
Location
Clevedon, UK
I write this in the hope that somebody will be able to help me.
I have an Acer Aspire 5520 AMD Turion 64 x 2 (2.0 Ghz, 3 GB RAM) (Vista Home Premium) which I purchased about six months ago. I loaded a lot of software onto this machine; however, I do not run much software at any given time. I have a serious problem.
Without warning and without predictability, the mouse pointer goes berserk, and the pointer moves, jerkily, all over the screen. This results in applications being triggered, windows being reduced in size, applications being terminated, and general shambles.
I have scanned my hard drive for scumware, spyware, and other forms of malware -- and every scan is negative. I use RegistryCleanerPro to check the registry (this tool cost me about £35.00), and every scan is negative for errors. This problem is driving me crazy, and I have no idea what I should do to resolve it.
My mouse is a standard, no-frills optical mouse by Technika (model TKOPTM2), which I bought from a store such as Tesco (I cannot remember exactly where I got the mouse, but there is nothing special about it).
Does anybody have any suggestions as to how I can get around this problem? Has anybody else experienced this problem? Is there a generic set of optical mouse drivers that I can download? If so, I would be very grateful if somebody would tell me where I can find these drivers.
I eagerly await feedback. I can be reached at philipchandler DOMAIN earthlink period net.
Thank you,
PHILIP CHANDLER
    Acer Aspire 5520
    AMD Turion 64 x 2 TL-60 2.0 GHz, 2 x 512 KB L2 cache
    3 GB DDR2
    15.4 " WXGA Acer CrystalBrite LCD (8ms/220-nit)
    160GB HDD
    Optical TECHNIKA
    Broadband
M
Malke
1. If the mouse is wireless, change the batteries.
2. Try a different mousing surface.
3. Try a different mouse.
4. Unrelated, but don't use registry cleaners.
http://aumha.net/viewtopic.php?t=28099 - registry cleaner thread
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
M
Mike Hall - MVP
"philipcfromnyc" <guest@xxxxxx-email.com> wrote in message
news:5278922ef8edf085d732fef8b5882b8c@xxxxxx-gateway.com...
> Thank you,
> PHILIP CHANDLER
> philipcfromnyc
If I were you, I would purchase a decent mouse. Logitech and Microsoft have
good ranges..
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default.aspx?pr=newswhelp&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
2
Location
Clevedon, UK
I tred using a different mouse, and obtained the same results. Both mice were optical mice. While both mice were relatively cheap, it does appear that the mice were not the cause of the problem (what are the odds of two mice from different manufacturers malfunctioning with exactly the same symptoms?). The surface on which they rest is smooth.
Does anybody have a link to a page where I can download generic mouse drivers?
Thank you in advance for any help that you may give me...
PHILIP CHANDLER
    Acer Aspire 5520
    3 GB DDR2
    160GB HDD
    Optical TECHNIKA
    Broadband
1,082
Location
Gladstone
Was the mouse which started the problem a new one? If so, and you installed a new driver try booting into Safe Mode, and uninstalling the mouse driver from Device Manager, it might be that "ghost" drivers are causing trouble.( You could try this anyway, it won't hurt as Vista will re-install it's generic driver)
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
S
> Thank you,
> PHILIP CHANDLER
> philipcfromnyc
Just for the heck of it move the antenna real close to the mouse if it works
better its a bad antenna. I had kind of the same problem you had,and when I
moved the mouse close to the antenna it worked fine. that means you will
have to buy a complete new mouse setup with antenna
