Mouse Scroll on Laptop
R
randy1200
I have a new laptop that came with Windows Vista. I recent had to format the
hard drive and re-install Vista. That went pretty smoothly.
Problem is that sometimes while dragging the mouse cursor across a window,
Vista tries to hold the mouse cursor in the center of the window and and
mouse movements scroll the window, not move the mouse cursor.
How do I turn this feature off? I never want a window to scroll unless I
explicitly grab and move a scroll bar.
Thanks,
Randy
B
Bridget
> Thanks,
> Randy
The auto scroll function that activates when using my touchpad is the most
annoying thing in the world. I'm here reading this forums, hoping to find a
way to make it stop. It's seemingly random and ends up costing me time and
effort. I don't know if it's a VISTA thing or an IE thing, but I hate it.
Help? Someone?
R
randy1200
Bridget,
I found with mine that the left side of the mouse pad is a scroll bar. If
you restrict your finger to the left 2/3s of the mouse pad you won't have a
problem. I never did figure out how to turn the scroll function of the mouse
pad off in Vista.
HTH...
Randy
> > Thanks,
> > Randy
> Help? Someone?
R
randy1200
Bridget,
I found that the right side of my mouse pad is a scroll bar. If I restrict
my finger to the left 2/3s of the mouse pad I don't have the problem. I never
did figure out how to turn the scroll bar part of the mouse pad off in Vista.
HTH...
Randy
> > Thanks,
> > Randy
> Help? Someone?
R
randy1200
correction: right side is scroll bar. left 2/3s is normal mouse pad.
"randy1200" wrote:
> Bridget,
> pad off in Vista.
> HTH...
> Randy
> > > Thanks,
> > > Randy
> > Help? Someone?
