Movie maker glitch
A
Aaron
When I publish video clips I've made in movie maker, or try burning them with
windows DVD maker, some files get cut in half with the top half being the
video I was using and the bottom half being a green bar. Is there a patch or
something to fix this?
The codec of the original video clips I'm using is XviD MPEG-4 Video Decoder.
J
John Inzer
> them with windows DVD maker, some files get cut in half with the top
> half being the video I was using and the bottom half being a green
> bar. Is there a patch or something to fix this?
> Decoder.
Maybe the following info previously posted
about the green bar issue will offer some ideas:
Here's the website I found by googling my problem:
Fixing the Green Bar Problem in Windows Movie Maker
http://www.bernzilla.com/item.php?id=884
When I tried to follow the directions, I was unable to find XVid on my
computer. So I googled XVid and then went to ( I think) the 2nd entry to
download XVid. After I downloaded it, I was able to follow the directions
from bernzilla and when I published a video - Voila!! no green bar!!!!
John Inzer
MS Picture It! -
Digital Image MVP
Digital Image
Highlights and FAQs
http://tinyurl.com/aczzp
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
W
WesW69
Thank you so much. Xvid was properly installed on my computer, so all I had
to do was check the box described in the article.
> > Decoder.
> John Inzer
> MS Picture It! -
> Digital Image MVP
> Digital Image
> Highlights and FAQs
> Notice
> I am a volunteer
