Movie Maker - issue importing mp3's
N
Nancy
I just tried importing an mp3 and I'm receiving the message: "mp3 could not
be imported. Class not registered." I don't know what this means. It's not
a protected file. This isn't the first movie I've made, but this is the
first time I've had a problem importing the music.
Any help would be greatly appreciated.
Thanks,
Nancy
N
Nancy
Thanks very much Edward, but unfortunately that didn't work.
Nancy
"Edward" wrote:
> "Nancy" <Nancy@xxxxxx> schreef in bericht
> news:2EFC6907-51DA-4277-9C04-AF6442718D9D@xxxxxx
> >not
> > not
> > Thanks,
> > Nancy
> Resave the mp3 it as a wave file and then convert it to mp3 again. I use the
> program Goldwave for that.
> Hope this helps.
N
Nancy
Just when I was beginning to like Vista... this is interesting... I tried
your suggestion and the message I get is "Windows cannot find
"regsvr32quartz.dll." I went into MM tools/options/compatibility to view
video/audio filters. The only filter listed is "AVI
Decompressor...windows/system32/quartz.dll".
Thanks again for your help, Edward.
Nancy
> news:01DD1756-DF90-4821-8D51-7ECB73E9D219@xxxxxx
> > Nancy
> >> the
> >> Hope this helps.
> maybe this will do the trick?
> http://www.free-codecs.com/guides/How_to_fix_Class_not_registered_or_80040154_error.htm
J
John Inzer
> tried your suggestion and the message I get is "Windows cannot find
> view video/audio filters. The only filter listed is "AVI
When running the command:
regsvr32 quartz.dll
There must be a space between the 2 and the q
John Inzer
Digital Media MVP
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
N
Nancy
Thanks John... I didn't notice the space, but it looks like it's gone from
bad to worse. After entering the info, a new error popped up: "Quartz.dll
was loaded, but the call to Dllregisterserver failed with error code
0x8007005." I hate to ask, but any thoughts on this?
Nancy
> regsvr32 quartz.dll
> John Inzer
> Digital Media MVP
> Notice
> I am a volunteer
N
Nancy
Thank you Cal Bear '66... that worked, but I'm still getting the "mp3 class
not registered" error message. I really appreciate everyone 's help with
this.
Nancy
"Cal Bear '66" wrote:
> You have to run the regsvr32 command from an "elevated" command prompt.
> Type cmd in the Start Search box above the Start Orb. When cmd.exe appears at
> the top of the Start Menu, right click on it and select "Run as Administrator".
> Then enter the regsvr32 command in the Command window and press Enter.
> I Bleed Blue and Gold
> GO BEARS!
> "Nancy" <Nancy@xxxxxx> wrote in message
> news:F1A1E1CD-4B39-461A-92D5-8BBA3C368EAF@xxxxxx
> > Nancy
> >> regsvr32 quartz.dll
> >> John Inzer
> >> Digital Media MVP
> >> Notice
> >> I am a volunteer
