Movie maker- what type of CD
J
I have finished making a video on Windows movie maker but I'm not sure what
kind of CD to buy to put the movie on a DVD. I realize that I should purchase
a DVD type CD but I don't know what the difference is between some of the
options. What is the best way to put the video onto some sort of media
(whether it is a CD or DVD). Thanks
Dzomlija
Resistance is Futile
2,213
Location
South Africa
I have finished making a video on Windows movie maker but I'm not sure what kind of CD to buy to put the movie on a DVD. I realize that I should purchase a DVD type CD but I don't know what the difference is between some of the options. What is the best way to put the video onto some sort of media (whether it is a CD or DVD). Thanks
CD-ROM is limited to 600, 650 or 750 MB, whereas DVD is 4.7 or 9 GB. Windows Movie Maker will give you about 150 minutes of video on a 4.7GB DVD. I've never used CD for video because compressing the video to fit 600-700 MB destroys the quality to a point where it's almost unviewable.
Worrying about whether you use DVD+R or DVD-R is almost a no-brainer, as most (if not all) DVD players recognise either type. Although in my experience, DVD-R writes slower, even if they are rated at the same speed as DVD+R.
Avoid using rewriteable or RAM disks (DVD RW and DVD RAM) for projects that are supposed to be "permanent" in nature.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
S
Symp EL
It depends on your dvd drive. Is it plus or minus or both? Chose the DVD
from there.
"jan" <jan@xxxxxx> wrote in message
news:BC274802-1363-4B8D-8954-043D7126520B@xxxxxx
> purchase
