Moving ads...
N1265
13
Hi guys,
I am new to Vista and I am having trouble getting rid of those Moving Ads, Like on E-Bay and other web sites.
Is there a way I can turn them off ?
Many Thanks,
32 bit Vista Home Premium
mark5019
76
try firefox with ad block, no script
    lenovo
    intel quad 2.4
    6GB PC2-6400 DDR2 SDRAM memory
    in vidieo
    High Definition Audio, 8 speaker configurable
    650GB 7200RPM Serial ATA hard drive
mansrm81
1,884
Location
Rockford, IL
You probably got infected with some adware so scan your computer with your virus program and your adware program.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
N1265
13
Ok, here is where I'm at as of today... I am running Norton Internet security 2009, I ran live update and a scan. It came back negative and made no difference in my problem. I am running firefox with Ad-block plus, In options on ad block plus I have the " show tabs on flash and java " UN-checked. Is this what you are talking about ? or do I need to download a different add on in Firefox ? I can go into Tools, options,content, and UN-check the " enable Java script " box and it will keep the ads from moving, However when I do this on some sites like E-bay it will not allow me to move from one page to another without re enabling Java script. Is there any else I can try ? those flash adds really mess me up on my consentration. Thanks,
mark5019
76
try to right click on ad and click block?
    lenovo
    intel quad 2.4
    in vidieo
Macavity
Nada y nada
39
Try...
FlashBlock
An example of results is below. One can click on the flash icon to play the add, or any other flash component of a website. Also, an option is provided to allow flash on sites.
    Dell Dimension 9200
    Intel Core 2 Duo 2.66 GHz
    2.00 GB
    Nvidia 8600 GTS (Overclocked)
    Dell 2007 WFP 27 in LCD
    1680 x 1050
    One (72.8/455 GB)
    Razer Salmosa
    Standard Dell Keyboard (Dusty)
