MS Paint text function grayed out
R
RayGo1975
OS : MS Vista Home Premium
I am trying to use MS paint and the 'A' tool on the tool bar is grayed out
and not clickable. Do I have to pay to use this tool?
Also if I go to view the 'Text Toolbar' option is checked but again it is
grayed out.
I am no expert on windows but I thought paint was included with the OS.
Any help is appreciated.
PS Don't bother telling me that some other program is better, I just need to
plan my flower garden and MS paint is fine for that.
R
RayGo1975
Never mind, I started drawing in lines and now I can add text. Don't know
what I did to get it turned on but it is fine now.
> grayed out.
A
Andrew Rossmann
[This followup was posted to microsoft.public.windows.vista.general and
a copy was sent to the cited author.]
In article <AA39BBF7-2F42-4F1C-9E57-1EE33C900086@xxxxxx>,
RayGo1975@xxxxxx says...
> grayed out.
Works fine on mine. Text Toolbar is greyed out until I click the 'A' and
draw a box where the text will go.
C:\Windows\system32\MSPAINT.EXE
Maybe it's trying to access a font that doesn't exist?
If there is a no_junk in my address, please REMOVE it before replying!
All junk mail senders will be prosecuted to the fullest extent of the
law!!
http://home.att.net/~andyross
Yeah RayGO... had the same problem... till I figured out you can't use the text facility while zoomed in or out beyond 100%. So go to "View" ad check that you're on 100% and it should be fine ;-)
