msn error code 80040154
J
jordan.nz
when i try sign into messenger it says service is temporarily unavilable and
give me error code 80040154, this has been happening for 3 days, i have
reinsatlled and updated messenger but it still gives the same error code.
any ideas?
J
Jonathan Kay [MVP]
Greetings Jordan,
Although this could be caused by a variety of things (it's trying to access a control which
isn't registered), generally the control that's not registered correctly is the Microsoft XML
parser.
The Messenger Support blog has a write-up on the steps to do this, so just head over to the
following link:
http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13936.entry
Jonathan Kay
Microsoft MVP - Windows Live Messenger
MSN Messenger/Windows Messenger
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2009 Jonathan Kay - If redistributing, you must include this signature or citation
"jordan.nz" <[email protected]> wrote in message
news:[email protected]
> any ideas?
M
MaysamSh
Cause: MSXML library may be corrupted and may have to be reinstalled
Troubleshooting steps:
Step 1. Re-register msxml3.dll
- Click on the Start menu, select Run and type the following:
Regsvr32 %windir%\system32\msxml3.dll
Hopefully, you will see a window popup that says: DllRegisterServer
succeeded in C:\Windows\System32\msxml3.dll is succeeded.
Step 2. Restart your computer and sign into Messenger again
if it registers with success and you still get the error number then
download this
http://download.microsoft.com//down...C35-EC1F888AC156/en/Contacts-ship-neutral.cab
unzip and run setup
> any ideas?
F
This worked!
> download this
> unzip and run setup
> > any ideas?
U
Usefkhoury
That's it :)
It worked
Thanks a lot
"Jonathan Kay [MVP]" wrote:
> Greetings Jordan,
> parser.
> following link:
> Jonathan Kay
> > any ideas?
Posts
16
Jonathan Kay [MVP];963542 said:
Greetings Jordan,
parser.
following link:
Jonathan Kay
MessengerGeek Blog: Jonathan Kay, MessengerGeek - Windows Live
Messenger Resources: MSN/Windows Messenger Resources
> any ideas?
i've done this and have the same error code, and yet nothing? any idea's would be appreciated, i have just fixed the problem of 'windows live communications platform stopped working' by running a repair programme after trying numerous thing, simple repair programme!
cheers,
Ed
J
jh6yythyhy
#8
> Greetings Jordan,
> parser.
> following link:
> Jonathan Kay
> > any ideas?
U
Umair
#9
Well, none of this works for me and when i go onto tools, options,
connection, i see a message that says "You are currently not connected to the
..NET messenger service" Why wont it work... Help....
> download this
> unzip and run setup
> > any ideas?
R
rhnyc
#11
Live Messenger has become a nightmar!! Every day there is a different error
code.
I wished so much to have the old version of Microsoft Messenger installed
without any "Live" or other whatever is screwing up the system!!!
I do not have WS7, I am not using Internet Explorer 8 - I have tried to
install the older versions of Messenger, but it "updates" it automatically to
the Live Messenger
Does anyone have a solution how to install and keep the old version??
Thank you
RH
> any ideas?
N
Nanels
#12
> any ideas?
