MSVBVM50.dll Problem
K
KillerK
Hi there,
I have just installed a program and everytime I try to run it, I get an
error saying that MSVBVM50.dll is required. I do not know what that is. Is
there anyway I can get the program to run? I have already tried compatibility
mode but that does not seem to help.
Thanks!
D
dean-dean
If you have access to a computer running Windows XP, you can Copy the file
msvbvm50.dll from C:\WINDOWS\system32\, and Paste it into the same folder as
the program's .exe file that requires it, for example, put it in C:\Program
Files\ MyProgram, if the MyProgram folder contains MyProgram.exe. It
shouldn't have to be put in Vista's C:\WINDOWS\system32\...
If you don't have access to an XP computer, go to
http://support.microsoft.com/kb/172991/EN-US/ , and download
http://activex.microsoft.com/controls/vb5/MSVBVM50.CAB . You can then
extract the file from msvbvm50.cab, and place in the folder as noted above.
"KillerK" <[email protected]> wrote in message
news:[email protected]
> Hi there,
> compatibility
> Thanks!
N
Naturewoman
I am having the same problem. I downloaded the MSVBVM50.dll file but can't
seem to extract it. I don't have a C:\Program
Files\ MyProgram, so tried to extract it into Vista's C:\WINDOWS\system32\,
but a window showed saying "access denied". Any help will be apreciated!
Thanks.
> "KillerK" <Kill[email protected]> wrote in message
> > Hi there,
> > compatibility
> > Thanks!
D
dean-dean
Try downloading MSVBVM50.CAB to your desktop, double-click on MSVBVM50.CAB,
then drag msvbvm50.dll out of the MSVBVM50.CAB "folder" to your desktop.
Right-click on msvbvm50.dll, choose Cut, and Paste it into the same folder
as the .exe file (program) that needs it.
"Naturewoman" <[email protected]> wrote in message
> Thanks.
>> file
>> as
>> C:\Program
>> above.
>> > Hi there,
>> > Is
>> > compatibility
>> > Thanks!
N
neu
I am having the same problem. I downloaded the MSVBVM50.dll file but dunno
where to paste it because i am installing a screensaver and it not showing
the target folder.
type of file - application.exe
description - install screensaver
D
DLL
i have the same problem whith DataStufion program i've downloaded the missing
DLL but still not working
"KillerK" wrote:
> Hi there,
> Thanks!
J
Jaidee
Thanks very much, your instructions were so clear & easy to follow, it worked
first time !
> > Hi there,
> > compatibility
> > Thanks!
P
Paulsmt
Even better, copy Both files contained within
to the desktop.
Right click on the MSVBVM50,inf Setup File, and click on Install.
(The Setup File has a picture with one gear, the other file has 2 gears.)
Now any program that needs it should run fine.
G
Gerbrand
thanks for the info. it worked!
> > Hi there,
> > compatibility
> > Thanks!
F
fat
"KillerK" wrote:
> Hi there,
> Thanks!
D
Dr. Ksd
It is Jan 2010 (2+ years after this post) and I used your link to resolve an
issue I had with a program I was unable to get rid of. I just followed your
instructions, placed it in the file and I was finally able to unistall it.
Thanks!!
> > Hi there,
> > compatibility
> > Thanks!
K
kamal
use regsvr32.exe to register
in command mode
run cmd
goto c:\windows\systen32
regsvr32 [location of the msvbvm50.dll]
S
SFVivian
I've been trying to get the DLL to copy to or open in the app file that needs
it but I get "access denied" (I'm the administrator and only user of this
laptop) or when downloaded it to the file it simply wasn't there when I open
the file. I'm running Win7, this dll worked when I ran Vista. Any
suggestions on how I can get the DLL into the file?
Thanks,
"dnjorogek" wrote:
> Hi,
> Had a similar error prompt on Windows 7, downloaded as per instructions and
> copied to the same folder as the APP i was running and worked fine ! As
> follows:-
> Extract the CAB and the files to the same folder location as the APP you are
> trying to execute.
> Regards,
> "KillerK" wrote:
> > Hi there,
> > Thanks!
