MSXML Fails to load document larger than 1 GB
T
Trey Shaffer
Forgive me, in advance, for this being vague...
First question, is this the right forum?
I am using MSXML within a vbScript, not associated with a web page.
My problem seems to be with size of an XML document.
I am using the .Load method as a simple validation tool to see if a file is well formed.
I download the file, via FTP, open it with MSXML, and check the return value for success/failure.
This works for files of size less than 1 GB, but fails for files greater than 1 GB. The threshold is close to 1 GB, though I haven't narrowed it with precision. 900 MB definitely works. 1.1 GB definitely fails.
Does this sound familiar?
Am I omitting anything?
Trey Shaffer
