Mustek 1200 UB Plus scanner driver for Vista
D
daidainius
Hello.
I have use Mustek 1200 UB Plus scanner. Unfortunatelly I can't found any
compatabile Vista driver for him. :(
Mustek website do not provide Vista drivers at present (I ask them).
Had somebody same problem?
Please suggest some solution or reply any comments.
Thanks for attention :)
N
NEWTECH
If you try to install Mustek 1200 UB plus XP drivers under Vista, You
will not be able to do it, because installer will say you “Only for XP”.
And Mustek corp. doesn’t expect to release update for Vista. I searched
online and found that a lot of people have troubles and problems with
it. BUT, fortunately, there is some workaround. Here it is:
- Extract it (You’ll see “Mustek 1200 UB Plus” folder)
- Plug your scanner (driver installation wizard will appear)
- Choose “Don’t search online”
- Then “Browse my computer”
- Then point to “Mustek 1200 UB Plus” folder
- Vista will install driver
That's all! Enjoy!
-Download Mustek 1200 UB Plus XP driver from official website (.exe
file)
-Execute it.
-You’ll see progress bar and the path to where it extracts installation
files.
- Then it asks about language
- When it asks you about language settings DO NOTHING. (Don’t
choose language)
- Instead of it go to your temp folder (follow the path)
- You’ll see WinXp folder <- This is YOUR DRIVERS (you can save
it)
- I just simply share it for your convenience
NEWTECH
NEWTECH's Profile: http://forums.techarena.in/members/newtech.htm
View this thread: http://forums.techarena.in/vista-print-fax/604982.htm
