My computer won't go to the sleep mode
S
spotsaddle
My computer is new and it used to to into the sleep mode. Now it says that
there is something wrong with the ATA Channel 1 and the drivers may need
updated. I am not sure what to do and I don't want to turn my computer off
each night and I also don't want to download something harmful that I am not
even sure what it is. any suggestions?
J
Jacmouth
I have the same problem. The sleep used to work fine, suddenly around 2
weeks ago it refused to go to sleep. The screen would shut off but
everything else is still on. I tried using the hotfixes microsoft had, but
all of them "doesn't apply" to my computer. I have a Latitude D630 with
Vista Ultimate. Also updated my graphics card and the bios, no luck. I
didn't install any software or hardware 2 weeks ago and there's no hardware
issues, I ran a complete test on that...anyone with any ideas?
starfox101
I had this problem come up, just could not understand why my system changed. I removed software, tried everything I could think of.. Anyway the problem for me was network sharing. When I enable share my media the system will not sleep.
Mason85
I'm having the same problem. When I linked my xbox 360 to my Pc, afterwards it would not sleep. Is there any way I can resolve the problem? If so how do I go about it?
Brink
Staff member
mvp
Hello Mason,
Double check with Step Two in the tutorial below and make sure that the "Multimedia Settings" is for "When sharing media" set to "Set to Allow the computer to sleep.".
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
    Lumia 1520 phone
Mason85
Having new problems with sleep mode, machine will either take a very long time to go into sleep mode or it takes so long that I just have to swicht it off at the button. I have run disk cleanup and checked my power settings. I have added a second monitor and switched to power saver mode, would this have anything to do with it? Could someone please help, thankyou.
Brink
Staff member
mvp
    Lumia 1520 phone
Brink
Staff member
mvp
thankyou that seems to have sorted my computers sleep problem now thanks.
You're welcome Mason. I'm happy to hear it is working for you now.
    Lumia 1520 phone
blackielude91
Sorry to bring back an old thread, but I figured I may as well not create a new one if this is relevant... I am having a problem with trying to get my computer to go to sleep. I regularly put my computer to sleep before i go to bed so the fan isn't being loud. I got an xbox 360 and sync'd it with media center and now my computer will not sleep. I unsync'd my xbox and computer, and it still will not sleep. Any suggetstions? I already tried step 2 on the power options link. I would really like to not deal with dell support again.
I have a Dell Inspiron 1720 running Vista 32bit.
Geekster
Just wanted to thank those who responded in this forum for helping me fix the sleep mode that had stopped working. It was the 'Allow the computer to sleep' under the Multimedia settings! Works like a charm now! I had enabled media sharing to share the media to another Vista PC and think this is what caused the sleep mode to stop working. Thanks again!
    Dell XPS 420
    Intel Core 2 Q6600 Quad Core (8MB L2 cache, 2.4GHz 1066FSB
    8GB Dual Channel DDR2 SDRAM at 800MHz - 4 DIMMs
    NVidia GeForce 8800 GT512MB
    24 inch E248WFP Entry Widescreen Digital Flat Panel Monitor
    1920 x 1200
    (2) 500GB - 7200RPM SATA 3.0Gb/s, 16MB Cache
    Wireless Intellimouse Explorer 2.0
    Microsoft Wireless Desktop Elite
    Roadrunner w/ Turbo Boost
    DIR-825 XTREME N Dual Band Gigabit Router
