My computer won't wake up from sleep mode
Patrik Habdak
Hello.
I've got an issue ..
1. Vista Business x86
2. Notebook FS Amilo Pro v3545 (T5500)
3. Sleep mode problem
The problem is, as title says, my computer won't wake up from sleep mode. When I try to wake it up, it takes about 2s to start and get to Login screen (as expected). After logging in, the problem becomes. It just freezes on "Welcome" screen. Not exactly freezes, mouse cursor is spinning, but no HDD activity is shown. Even after an hour it didn't move.
So .. I did some diags.
And here is my result:
powercfg /a
The following sleep states are available on this system: Standby ( S3 ) Hibernate Hybrid Sleep
The following sleep states are not available on this system:
Standby (S1)
The system firmware does not support this standby state.
Standby (S2)
So .. looks like my firmware (I bet bios or drivers) fails with S1 mode. However .. I used sleep, also hibernate and also hibernate hybrid sleep before. This problem is since new install of my OS.
Ok .. so .. I tried to update my bios. Great, I have found a version from 2007, the newest one and replaced my version from 2006 :zip:
No major changes in bios were found and also it didn't solve my problem. I have decied that, this can't be bios problem (ACPI) at all.
After this ..
sfc /scannow
2010-04-26 08:48:17, Info CSI 00000147 [SR] Cannot repair member file [l:24{12}]"cscompui.dll" of NetFx-CSharpCompilerMsg, Version = 6.0.6000.16588, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:b03f5f7f11d50a3a}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-04-26 08:48:24, Info CSI 00000149 [SR] Cannot repair member file [l:24{12}]"cscompui.dll" of NetFx-CSharpCompilerMsg, Version = 6.0.6000.16588, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:b03f5f7f11d50a3a}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-04-26 08:48:24, Info CSI 0000014a [SR] This component was referenced by [l:170{85}]"Package_1_for_KB110806~31bf3856ad364e35~x86~~6.0.6000.1433.110806-230_RTM_neutral_GDR"
2010-04-26 08:48:24, Info CSI 0000014d [SR] Could not reproject corrupted file [ml:520{260},l:108{54}]"\??\C:\Windows\Microsoft.NET\Framework\v2.0.50727\1033"\[l:24{12}]"cscompui.dll"; source file in store is also corrupted
Dunno why, but I have feeling this is my problem. Sleep (S1) is sleep for CPU and I've got CPU problem here. Any ideas?
    Intel Core 2 Duo T5500 1.66GHz
    Fujitsu-Siemens
    4GB DDR2 800MHz CL5
    nVidia GeForce GO 7300
niemiro
Banned
Hello.
powercfg /a
Standby (S1)
Standby (S2)
After this ..
sfc /scannow
Hello and welcome to the forum :party:
There is no CPU issue here. The only issue SFC found is cscompui.dll. Please install the .net Framework 2.0 again (over the top of your current install) or repair if that option appears. Here is the download:
Download details: .NET 2.0 SP1 (x86)
Then re-run SFC and see if this error still shows up.
For your sleep problem, please methodically work through this tutorial: http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Patrik Habdak
Thank you very much. Problem with framework solved. But I have already tried the tutorial without success.
    Fujitsu-Siemens
    4GB DDR2 800MHz CL5
