my computer worth overclocking?
112
i have a hp p6649c it has a amd quad 635 2.9 cpu 1 tb hard drive 16 gig ddr3 ram integrated sound and integrated graphicsany help would be most appriciated.
and also if it is worth it i'll need instructions on how to do it
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    hp 27 inch 1080p and gateway 23 inch 1080p
    western digital 1tb
    stock 250watt
    stock
    stock
    logitech k320 wireless
    comcast cable 20meg
richc46
Staff member
20,105
Location
Fairfield County, CT
112
enough said right there i never want to experience the bsod after we get this taken care of i dont even want to overclock now thank you and i will post my dump logs from the verifier tomarrow morning Richard, i assume the tips for speeding up vista also work for speeding up windows 7 or am i incorrect?
also as one stated installing more memory and i plan to however my question is that with the bsod issue we are working on at present is it okay to install new ram or will it be infected by the present issue rendering it useless if i were to use it in any other computer?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
richc46
Staff member
20,105
Location
Optimize Windows 7 - Windows 7 Forums
You can install the new ram, but if you have a virus there will still be problem. The virus however does not affect the ram. Once you get rid of the virus, you will be ok. That being, said, I would wait. Lets not try to create more issues before the prior ones are taken care of.
112
roger that thanks for the response i will wait, did you see my post about my keyboard freezing and not responding i posted back over in crashes forum?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
townsbg
~~тσωηsвg~~
2,248
Location
US of A
Dude if you have 16 gb then you already have way more ram than 7 needs. There is almost no possibility that you are using up all that ram therefore more ram probably won't help. You are no better off with 16 than with 6 just as long as you have enough to run the programs that you normally run. I think that the insane amounts of ram installed in today's computers are usually unnecessary and just a waste of money. Open task manager and you can see in the bottom right hand corner the amount of physical memory in use. Unless you are usually at or over 100% more ram won't help. Do yourself a favor and save your money.
In addition according your the system specs 16 gb is all your system currently supports. So you can't add more.
    Mid 2010 iMac
    3.2 Ghz I3
    8 gb
Patonb
2,245
For the record, overclovcking is always worth it... Free performance and when setup its stable and 0 BSOD. So i fully disagree with rich.
If youre bsoding you are not overclocked properly. I run 4.0Ghz on my i7 950 24/7 365 and i fold@home, so i'm not just and idle computer.
All that said, you can't overclock. All but a scant few prebuilt computers have locked BIOS so its impossible. Then theres allk the cooling issues associated with prebuilts.
So yes your computer would rock overclocked, but its not possible, and would burn up yoyr parts if you do.
Btw, if Towns correct, and you have 16Gigs, and youre bsoding... its because of too much ram and not enough power.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
richc46
Staff member
20,105
Location
#8
I disaagree with Patomb, leave the computer at factory specs. The manufacturers of the computers know the best comb of speed and reliable performance. What you get with OC is not worth it (that last portion is subjective)
112
#9
toeply to town iam currentlg 67% memory and to address the issue of power supply vs ram with my stock 250w(i know weak) should i throw the 500w i got laying here in the computer?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Patonb
2,245
#10
No the factories do not, they build their systems so that to get a more powerful setup, you have to buy a new one from them., Infact most prebuilts run more Vcore than is required. Most likely so thgat there is not a chance a power issue happens.
If that were true, then the chips would not have variables built into the cpu to change the speed.
The difference between the 1366 i5/7 chips is the multipliers... a 920 has a 20 multi, the 950 has a 24. Same exact chip.
Intel has designed their products to do it, and the companies purposely lock them out so as they can't. You can get the exact mobo oem in a hp or buy one from the manufactuer and it'll be unlocked.
All that said, overclocking isn't something that is easy or garrenteed to do, or to get a solid high oc... but it is definately doable, and has extended the life of many systems when they get older.
I replyed in your bsod topic on the psu, as its a completely different subject.
townsbg
~~тσωηsвg~~
2,248
Location
US of A
#11
Do you really have 16 gig? If so what are you running that's taking up over 10 gb? Regardless your computer isn't designed for more than 16 however that might change with a future bios update. For the record I don't recommend a bios update.
    Mid 2010 iMac
    3.2 Ghz I3
    8 gb
112
#12
yes i have 16gig i use auto cad and i do alot of video editing,however my hard drive crashed and i put in a 1.5 tb and attempted to use the resteore disks from my hp to load the operating system but iam getting a error message saying the drive is part of a paton i didnt think the oem restore disks were tied to the hard drive as well only the motherboard correct?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
112
#13
hp machines blow the motherboard and the hard drive are both tatooed you cant change the power supply as the motherboard recieves its dmi number from it and if the powersupply does not supply the correct dmi number its a no go so basicaly if anything takes a crap on a hp your out of luck unless you spend ungodly amounts to buy the parts from hp sorry had to vent a bit
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
townsbg
~~тσωηsвg~~
2,248
Location
US of A
#14
Well that stinks. I knew that the disk is tied to the computer (that's common) but I didn't know that about the hard drive. How did you confirm that?
    Mid 2010 iMac
    3.2 Ghz I3
    8 gb
112
#15
hp customer service after about 3 hours of b*tching i finaly got hp to replace my motherboard cpu hard drive optical drive and psu plus there sending me a box and a prepaid label to send this paperweight to them so hopefuly that will solve my issue since all that is left is the memory (yes some how the optical drive is tied in for reading recovery disks only if the recovery disk doesnt read the imbedded code from the optical drive the recovery dicks will not work otherwise you can change the drive all you want it only has to be the stock one to read recovery disks that was told to me by the manager of the service department scheduling my repair
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Patonb
2,245
#16
****ty, well if theyre gtoing to do it, thats something to celebrate. G/l with it all
112
#17
now you said that 16 gigs is a bad idea so if i remove the 16 gigs and were to step down to say 6 gigs the problem i see is that since it is dual channel memory and i would be using a odd number of dimm slots for 6 gigs(3 dimms) it would revert the memory back to single channel would i be better off only using 2 of the 3 sticks and have 4 gigs so it remains dual channel? or should i go out and buy a 8 gig kit 4x2
thanks for the help
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Patonb
2,245
#18
You probably need only 8. Especially with problems occurring. Once fixed up, no reason to try 16.
