My PCs wake up by themselves from standby or hibernation!
H
Hal9000
I'm having this problem since some months now: my PC randomly powers up by
itself when in hibernation or standby, which is very annoying.
I also have a laptop which has the same problem. This sucks, since sometimes
i want to use it and the battery has been killed because it powered itself
up and ran all the time without me knowing.
Both machines are running Vista. All the wake-up options in the BIOS are
disabled, and there are no wakeup timers in the BIOS. The laptop powers up
even if nothing is connected to it (no network, no usb, no nothing).
What the hell is going on? How can I prevent my pcs from waking up by
themselves? When I put them in hibernation or to sleep, i just want them to
stay there until I power them up by myself. Just using shutdown is not a
solution :(
I hope you can help me to find a solution...
hal
F
Frank Saunders, MS-MVP OE/WM
"Hal9000" <hal9000@shovelspam.com> wrote in message
news:F2BF114C-2595-4777-9414-8B2326EB471E@microsoft.com...
> sometimes
> to
> solution :(
> hal
Turn the mouse over onto its back.
http://www.fjsmjs.com
That's a good one. I like it. A little levity never hurt anyone.
> > sometimes
> > to
> > solution :(
> > hal
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hi Hal9000,
Check Task Scheduler for any scheduled tasks that have "wake the computer" under the Conditions tab. Don't forget to check "Show hidden tasks" under View in right pane.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
F
Not levity. Vibration moving the mouse often wakes computers up. Turning
it over prevents this.
"CB" <CB@discussions.microsoft.com> wrote in message
news:F8E4AAC0-9069-4938-9B9D-15852BC170A3@microsoft.com...
>> > by
>> > sometimes
>> > itself
>> > are
>> > up
>> > them
>> > to
>> > a
>> > solution :(
>> > hal
Sorry. I thought you were joking. It made me laugh. Anyway, I guess I learn
something new every day. Thank you for the information.
C.B.
"brink" wrote:
> Hi Hal9000,
> Hope this helps,
> Shawn
> brink
> "Practice makes perfect, then you reinstall"
> Vista 64 Home Premium
> 1.5 Gig DDR2 533 Mhz (PC4200) RAM
H
Hal9000
under "MobilePC" i had a task called "TMM"(whatever that is) with the wake
option enabled. i disabled that options, now i hope it will fix the
problem...
hal
"brink" <brink.2q3ew4@no-mx.forums.net> wrote in message
news:brink.2q3ew4@no-mx.forums.net...
> Hi Hal9000,
> Hope this helps,
> Shawn
> brink
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#8
problem...
hal
no-mx.forums.net...
Here's a link that explains the TMM: (Transient Multimon Manager)
http://whitepapers.techrepublic.com.com/whitepaper.aspx?docid=150397
However, this may not be it though. I checked mine to & it was enabled with wake to without any problems.
I guess if all else fails you can turn off "sleep" & "hybrid" & just use "hibernation" in Power Management. It'll take 30 seconds or so wakeup, but at least everything will shut down completely. No more hunting for what might be running to cause it to wake up.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
H
Hal9000
#9
my pcs even wake up when hibernated! only a shut down will prevent them from
turning on :(
"brink" <brink.2q7y32@no-mx.forums.net> wrote in message
news:brink.2q7y32@no-mx.forums.net...
>> wake
>> problem...
>> hal
>> 'no-mx.forums.net' (http://no-mx.forums.net)...
> '_http://whitepapers.techrepublic.com.com/whitepaper.aspx?docid=150397_'
> (http://whitepapers.techrepublic.com.com/whitepaper.aspx?docid=150397)
> Shawn
> brink
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#10
turning on :(
Ok Hal9000,
I found this new method for you.
1. open Command Prompt
2. type "powercfg -lastwakup"
3. hit enter
This will tell you what woke up your computer the last time. Now, the trick will be IDing what is spits up is the cause.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
H
Hal9000
#11
C:\Windows\system32>powercfg -lastwake
Wake History Count - 1
Wake History [0]
Wake Source Count - 0
Hm... how do I interpret this information?
hal
"brink" <brink.2qa5y0@no-mx.forums.net> wrote in message
news:brink.2qa5y0@no-mx.forums.net...
>> from
>> turning on :(
> Ok Hal9000,
> 3. hit enter
> Hope this helps,
> Shawn
> brink
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#12
Wake History [0]
hal
>> from
>> turning on :(
> Ok Hal9000,
> 2. type "powercfg -lastwake"
> 3. hit enter
> Hope this helps,
> Shawn
> brink
OK,
That didn't spit out anything useful now did it. Try this instead:
1. open command prompt
2. type "powercfg /?" (no quotes)
3. hit enter
You'll get a list of all available command options with details on powercfg.
scroll down to the "DeviceQuery" section and follow instructions to run. This will list all devices on your computer that can wake it up. We'll then have to go one by one & check the little buggers. It looks overwhelming, but it is easy to work with. Post back for help on this and results.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
H
Hal9000
#13
Log Name: System
Source: Microsoft-Windows-Power-Troubleshooter
Date: 13.05.2007 08:08:46
Event ID: 1
Task Category: None
Level: Information
Keywords:
User: LOCAL SERVICE
Computer: Hal9000
Description:
The system has resumed from sleep.
Sleep Time: 13.05.2007 00:06:47
Wake Time: 13.05.2007 06:08:41
Wake Source: Unknown
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Power-Troubleshooter"
Guid="{cdc05e28-c449-49c6-b9d2-88cf761644df}" />
<EventID>1</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2007-05-13T06:08:46.000Z" />
<EventRecordID>57725</EventRecordID>
<Correlation ActivityID="{D3F1C24F-3DD8-4B7C-A8AC-B98024A62376}" />
<Execution ProcessID="1604" ThreadID="6260" />
<Channel>System</Channel>
<Computer>Hal9000</Computer>
<Security UserID="S-1-5-19" />
</System>
<EventData>
<Data Name="SleepTime">2007-05-13T00:06:47.761Z</Data>
<Data Name="WakeTime">2007-05-13T06:08:41.882Z</Data>
<Data Name="SleepDuration">34011</Data>
<Data Name="WakeDuration">4649</Data>
<Data Name="DriverInitDuration">4324</Data>
<Data Name="BiosInitDuration">0</Data>
<Data Name="HiberWriteDuration">134387</Data>
<Data Name="HiberReadDuration">14894</Data>
<Data Name="HiberPagesWritten">109351</Data>
<Data Name="Attributes">16403</Data>
<Data Name="TargetState">5</Data>
<Data Name="EffectiveState">5</Data>
<Data Name="WakeSourceType">0</Data>
<Data Name="WakeSourceTextLength">0</Data>
<Data Name="WakeSourceText">
</Data>
</EventData>
</Event>
This morning my pc woke up by itself from hibernation. Unfortunatelly no
indication of what the cause could be! :(
hal
"brink" <brink.2qdkvi@no-mx.forums.net> wrote in message
news:brink.2qdkvi@no-mx.forums.net...
>> Wake History [0]
>> hal
>> them
>> >> from
>> >> turning on :(
>> > Ok Hal9000,
>> > 3. hit enter
>> > Hope this helps,
>> > Shawn
>> > brink
> OK,
> 3. hit enter
> powercfg.
> and results.
> Hope this helps,
> Shawn
> brink
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#14
Log Name: System
Event ID: 1
Task Category: None
Level: Information
Keywords:
User: LOCAL SERVICE
Computer: Hal9000
Description:
Event Xml:
<System>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
</System>
<EventData>
</Data>
</EventData>
</Event>
hal
Well Hal,
Let's hope it was just one of those Vista flukes and your computer will wake up ok from now on. I don't see anything in that report either.
Glad to hear,
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
J
Joe Guidera
#15
What does "powercfg -DEVICEQUERY wake_armed" display? (from a command
prompt)
J
"brink" <brink.2qiin0@no-mx.forums.net> wrote in message
news:brink.2qiin0@no-mx.forums.net...
> Hal9000;307308 Wrote:
>> Log Name: System
>> Event ID: 1
>> Task Category: None
>> Level: Information
>> Keywords:
>> User: LOCAL SERVICE
>> Computer: Hal9000
>> Description:
>> Event Xml:
>> <System>
>> <Level>4</Level>
>> <Task>0</Task>
>> <Opcode>0</Opcode>
>> </System>
>> <EventData>
>> </Data>
>> </EventData>
>> </Event>
>> no
>> hal
> Well Hal,
> Glad to hear,
> Shawn
> brink
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#16
prompt)
Hi Joe,
It lists the devices that are currently enabled to wake your computer from any sleep state.
Type powercfc /? in the command prompt for a complete list of codes and what they are for.
Hope this helps you,
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
S
spoco2
#17
I just want to say that I'm having the EXACT same problems and get the same
output from powercfg... it's driving me nuts.
When I initially did a wake_armed list in power_cfg I found that my mouse,
keyboard and HD audio were all wake armed, even though I had definitely
disabled the mouse and keyboard. Anyway, I've done it again and now all I'm
left with is the HD Audio (motherboard onboard sound), and yet my system
still wakes up.
I hope that whatever may be found to help the OP can help me too!
Simon
"brink" wrote:
> > prompt)
> Hi Joe,
> Type *powercfc /? *in the command prompt for a complete list of codes
> Shawn
> brink
J
JethroUK©
#18
i think it's called 'wake up on lan' and you have to disable it from the
bios (F10 on boot up i think)
"spoco2" <spoco2@discussions.microsoft.com> wrote in message
news:AF33732C-0C59-4118-8A07-C39AC1C16AE6@microsoft.com...
> I'm
> still wakes up.
> Simon
>> > prompt)
>> Hi Joe,
>> Shawn
>> brink
S
spoco2
#19
Was one of the very first things I disabled in bios, along with wake on
mouse and wake on keyboard.
I've then also done that within Vista also, via the properties of each of
those devices... and turned of the ability for any of the usb host
controllers to wake the system.
I just have absolutely NO idea why my machine keeps turning on, and I
believe that's the same boat as the OP.
> > I'm
> > still wakes up.
> > Simon
> >> > prompt)
> >> Hi Joe,
> >> Shawn
> >> brink
J
JethroUK©
#20
have you tried 'power options>advanced settings'?
news:45EB802D-D09A-4F13-BC4B-0400B13F00BE@microsoft.com...
> Hi,
>> >same
>> > mouse,
>> > I'm
>> > system
>> > still wakes up.
>> > Simon
>> >> > command
>> >> > prompt)
>> >> Hi Joe,
>> >> Shawn
>> >> brink
