navigation to webpage was cancelled
B
bob e lee
for no apparent reason i get a window that pops up on occasion that gives me
the error, "navigation to web page was canceled"
How do I isolate the program that is causing these errors and then how to i
resolve the issue?
I have Vista, Office 2007, IE7
O
ob11178
I have the same problem does anyone know how to fix it... I tired of it
> resolve the issue?
O
ob11178
I found these post and they helped me... Hopefully they help
I also have the most annoying popup with the above referenced message. I
tried a suggestion from stormrider550
"Go to control panel... administrative tools... task scheduler. Delete the
Internet Offers task and the Registration task" I was unable to delete these
and after playing around with various other things, I am still getting this
popup - mine appears every minute or so so it is so annoying - I've been
using alt F4 to clear it - but am getting so sick of it.
Here is what you do to get rid of the problem. Do as the previous user
suggested...that is, go to Control Panel, click on System and Maintenance,
then scroll down to Administrative tools and click on Schedule Tasks. Under
"Acive Tasks" on the bottom of the screen, double click on
"InternetServiceOffers" and it will open up a new screen. At the top, under
"Name" you should see InternetServiceOffers. Left-click on it to highlight
it, and press your "delete" key. It should delete the file. It may ask for
confirmation. Hope this helps. Thank you everyone who responded earlier, as
it helped me.
"johnsmith74" wrote:
> how do i stop navigation to webpage was canceled
> johnsmith74
D
dsmobster
Yes, this was helpful but to delete or suspend tasks one must goto the task
library(left hend side of screen) and gives the options to run, delete and
disable tasks. I have been workin with a Compaq SR5214 but seems common to
all the HP brand. It occured after I had 'de-krapped' this PC.
Otherwise...these would pop up while in use propting one to sign up for
internet services or make back-up discs(I did) and such. There are many many
scheduled tasks and is all confusing but the more you read, the more you
learn =)
> it helped me.
> > johnsmith74
bas
i don't have that active tasks you are saying the Internet service offers. Please help me. still this message is still coming, whole day now i am trying to get rid of it. I cannot
