NavigationWindow Template
S
Stephen Planck
When testing a previous version of WinFX with VS 2005 beta 2, there was a
template that allowed you to create a NavigationWIndow application. Now in
the release version of VS 2005 and the December CTP of the Windows SDK, the
template no longer appears to exist.
I know you can fix this by writing a little code, but does anyone know what
happened to the separate template? It's something you wouldn't think would
be taken out.
Just curious.
Steve
D
Drew Marsh
> was a template that allowed you to create a NavigationWIndow
> application. Now in the release version of VS 2005 and the December
> CTP of the Windows SDK, the template no longer appears to exist.
> what happened to the separate template? It's something you wouldn't
> think would be taken out.
> Just curious.
Is your questions just "why did they remove it from the SDK?" If so I don't
know, but it's still possible to do last I checked. Check out this thread[1]
for details.
HTH,
Drew
[1] http://msdn.microsoft.com/newsgroup...&p=1&tid=965462c5-2c37-45de-96ad-85f4af0128d3
