Need help in printing via the old "LPT" port in Vista
M
Michael B.
I am using an old DOS-based program which is very old, but very convinient
for me to use. In Windows XP, I was able to get around this problem by
using the following commands:
Start
Run
CMD
net use lpt1 \\violin1\brother /persistent:yes
where "violin1" is the computer name and "brother" is the printer name.
See the following link:
http://support.microsoft.com/default.aspx?scid=kb;en-us;314499
I have also verified using the "net view \\violin1" command that "Brother"
is being used as LPT1 for Printing"
However, when I try to use the print command within the DOS program, nothing
happens. No errors, but just sits there until I manually close the window.
I am running my old DOS-based program to be compatible under Windows 95.
Anyone with ideas as to why this is not working with Vista Ultimate?
R
Rick Rogers
When you go to invoke the cmd.exe file, right click it and use "run as
administrator". See if it helps.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Michael B." <mystic02removethisplease@verizon.net> wrote in message
news:5uTKh.182$Sf2.61@trnddc01...
> Start
> Run
> CMD
> nothing happens. No errors, but just sits there until I manually close
> the window. I am running my old DOS-based program to be compatible under
> Windows 95.
