Need to get rid of Live Messenger on 32 bit XP pro system
T
The1Trafficman
I have a very corrupt version of Windows Live Messenger on a 32 bit XP pro
system. It started as a virus that I was able to get rid of. Everything but
meesenger works fine. When I attempted to uninstall it the system reported
that the files do not exist. When I try to reload it the system reports that
I already have it. I looked on the C drive and all but three files are
missing from the Messenger folder. When I try to delete that folder it tells
me the remaining files are in use. I am at wits end here and really do not
want to wipe the machine and start over. Anyone with any ideas I would really
appreciate it....Thanks!!
J
Jonathan Kay [MVP]
Greetings,
ZapMessenger should help you out:
http://messenger.jonathankay.com/redir/zapmessenger.asp
Jonathan Kay
Microsoft MVP - Windows Live Messenger
MSN Messenger/Windows Messenger
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2010 Jonathan Kay - If redistributing, you must include this signature or citation
"The1Trafficman" <[email protected]> wrote in message
news:[email protected]
M
margbounty
it started yesterday morning at 11:30. no upgrades no third party stuff
Version: Windows live latest I believe since i only downloaded it and
installed it the week before. Vista (I hate it) only one but i didn't think
WoW would mess with the window messenger
the font isn't white it purple like i always have it. and I tryed changing
the font.
the only thing that show up is
*_________
*__________
and if you click the top line you get the history and if you highlight in
between the lines you get staggered blue marks like this
l
l
l
l
the lines aren't visible but space is highlighted like they are there.
Handwriting messages is fine though (but it is to hard to have a
conversation that)
