Need vista 64 & 32 & xp pro compatible ext drive
Cher (BIRDWISE)
WinXP Pro/Vista32/64 bit
I'm in dire need of a portable external drive, preferably a 2.5" or smaller, external drive that I can move my photos from (and files) one pc to another....more precsely from one vista 64 laptop and or vista 32 bit to a desktop that is xp pro os.
I have a large My Book by Western Digital and a passbook 120 gig by Western Digial to> Nothing works.
I've got a dvice that has two USB connections one on each end that is a data trasnfer divice. i wonder if anyone has ever used these and any adivce?
I need a drive for my millions of photos before I ruin another laptop; mut be mved to desktop>
Have looked everyplace online> Thanks, Cher (BIRDWISE)
geezer10
Engineer
Vista Pro
hi cher,
you say nothing works - surely your desktop can see the WD drives?
make sure everything is turned on before connecting together.
I got one of those usb to usb things never did try it -
Do you have network connectors on the computers?
Cher (BIRDWISE)
Hello,
No, the desktop no longer sees it; it just beeps like a robot. :(
One of the laptops used to recognize it only that was teh 64 bit...now nada.
I have one of those. G I don't know enough about file types to use it. Do you know how to use it? I;m willing to give it a try becaue am desperate.
What forgive my ignorance, is a network connector? I appreciate yout help very much, Cher
Zdon
Don't worry be happy.
If your drives used to work on both computers, then you should be able to get them to work again. I would work on this option before buying a new drive that, given your circumstances, might not work either. Perhaps you simply need to reinstall the drivers for the drives on the various machines.
