.NET2 TextBox & DWM
J
Jan Kucera
Hi.
First of all, I have extended glass to my client area and I want to put a
search textbox on it. The biggest problem is, that the text inputed is
rendered in glass regardless the foreground color I set to the textbox...how
to avoid this?
The second question is how can I make it glass semi-transparent like these
in explorer windows? I believe this can be done by the dwm blur api but I
haven't managed it to work in C#...
Thanks for any help.
S
Stefano Lanzavecchia
I don't know if you've seen this already... On the page
http://www.microsoft.com/uk/msdn/events/nuggets.aspx click "Show All" and
look for the one called "Glass with C# in Windows Vista". I've watched it a
while ago but I seem to remember it covered your question... Forgive me if
it doesn't and I ended up wasting your time...
-- Stefano
J
Jan Kucera
Hi Stefano,
really thanks for this link. This answers the question how to use blur api
and what it is for (creating glass area inside a form). It does not explain
the problem with TextBox (and any other WinForms controls), however,
explains the second approach to get glass which I believe will not make
these troubles.
The semi-transparent textbox, as someone has answered me on forums, is done
using such background image.
Thanks, I recommend this video for all starting with glass! ;-)
Jan
"Stefano Lanzavecchia" <[email protected]> wrote in message
news:[email protected]
>> these in explorer windows? I believe this can be done by the dwm blur api
>> but I haven't managed it to work in C#...
> a while ago but I seem to remember it covered your question... Forgive me
> if it doesn't and I ended up wasting your time...
> -- Stefano
