Network and Sharing Center some can't be turn off
I'm using dial-up. On Sharing and Discovery i can not turn off Network
discovery and File Sharing because the on and off, apply button is greyed
out. How do i turn off Network discovery and File Sharing? and what exactly
does Network discovery do?
E
did you find a fix? I have the same problem
M
mnthompson
Net Discovery simply allows you to view neighboring PC's & devices. as
well as allowing you to be seen in some instances. Check to see if your
network is showing up as undefined or if it is public. either of these
options may be the reason the selctions are greyed out.
mnthompson
Posted via http://www.vistaheads.com
