Network Usage Percentage
B
Brian H.
I've been digging through WMI trying to figure out how I can check network
usage percentages. You know, if you go to the Windows Task Manager,
Networking tab, you can see a graph of usage. I'd like to be able to check
this remotely via PSH periodically.
Any ideas?
Thanks
Brian H.
J
> Any ideas?
> Thanks
> Brian H.
It looks like the Win32_PerfRawData_Tcpip_NetworkInterface class will
give you what you want. Try looking at the BytesReceivedPersec,
BytesSentPersec, BytesTotalPersec, and CurrentBandwidth properties;
you should be able to calculate usage percentages with those values.
Jeff
K
Kirk Munro
Hi Brian,
If you have the PowerGadgets snapin, you should be able to create a
PowerGadget (I recommend a gauge) and have it automatically refresh at the
interval you specify. Then you could just monitor it on your desktop. I
wouldn't mind experimenting with this and have access to that snapin, so if
you determine the script to calculate the percentage and want to share it
here, I'll give it a whirl and share the script for the PowerGadget back
once I'm done.
Kirk Munro
Poshoholic
http://poshoholic.com
"Jeff" <jeff.hillman@xxxxxx> wrote in message
news:1193808779.091208.230080@xxxxxx
>> network
>> check
>> Any ideas?
>> Thanks
>> Brian H.
> Jeff
N
nsoftware
Just one more note - you can also do this with SNMP.
Lance
http://geekswithblogs.net/Lance
S
Shafik
> Lancehttp://geekswithblogs.net/Lance
you can start with that (break on Ctrl+C):
$net = new-object
System.Diagnostics.PerformanceCounterCategory("Network Interface")
$name = $net.GetInstanceNames()[1]
$down = New-Object System.Diagnostics.PerformanceCounter("Network
Interface", "Bytes Received/sec", $name)
$up = New-Object System.Diagnostics.PerformanceCounter("Network
Interface", "Bytes Sent/sec", $name)
$dlOld = $down.NextSample().RawValue
$upOld = $up.NextSample().RawValue
while ($true) {
$dlValue = $down.NextSample().RawValue;
$upValue = $up.NextSample().RawValue;
$dlSpeed = $dlValue - $dlOld
$upSpeed = $upValue - $upOld
$dlOld = $dlValue
$upOld = $upValue
write-host -nonewline "down: " ([int]($dlSpeed / 1024)) " up:
" ([int]($upSpeed / 1024))
write-host " " -nonewline
for ($i=0; $i -lt 30; $i++) {
write-host -nonewline "`b"
sleep 1
L
Lance
> I've been digging through WMI trying to figure out how I can checknetwork
> Any ideas?
> Thanks
> Brian H.
Lance
