Networking Woes
A
amatie
I just built a new system with Vista Ultimate 64 bit, and am running Norton
Internet Security.
I have 2 computers running Win Xp Pro that are networked, neither can see
the Vista machine, and the vista machine cannot see the xp machines. I can
ping all machines from any machine, so I should have Firewall configured
properly. I have identical user names on all 3 systems, and have shared
folders/files. I frankly am at a loss and would welcome any suggestions/
answers.
S
Here are some things to check (if you haven't done so already):
1. Make sure the XP computers have the same workgroup name as the Vista.
The default name that Vista gives is WORKGROUP. Give the same name to your
workgroups on the XP computers (I am told that XP has a different default
name).
2. On the Vista, in the Network and Sharing Center, make sure Network
Discovery is ON, File and and Printer Sharing is ON, Public Folder Sharing is
ON, Password Potected File Sharing is OFF.
3. On the Vista machine, try turning off Norton Internet Security and
turning on Windows Firewall with its recommended settings. This apparently
has a bearing on Network Discovery.
Shri
> Internet Security.
> answers.
A
amatie
tried that even tried with no firewall on and had nothing, willing to try
another suggestion here.
> name).
> Shri
> > Internet Security.
> > answers.
A
amatie
UPDATE --
I can see both XP machines as Media Players.
> > name).
> > Shri
> > > Internet Security.
> > > answers.
S
Here are some other suggestions:
1. Vista machine: Set Network Location to Private
2. Vista Machine: Enable Windows Firewall exception for Network Discovery
3. Reset Vista machine network adapter
Sorry don't know much about XP. The above and previous suggestions (and
others)are things I have tried with no luck getting my Win 98SE machine and
Vista machine to "see" each other. Like you, I too am able to do two-way IP
address pings successfully.
Shri
> > name).
> > Shri
> > > Internet Security.
> > > answers.
A
amatie
I already did 1&2, just tried 3 still nothing. wow this is frustrating, I am
so glad that at least for now i can use my flash drive to transfer data, but
it's not the fastest way to do it.
> Shri
> > > name).
> > > Shri
> > > > Internet Security.
> > > > answers.
A
amatie
Partial Success
I can type "\\comp name" and access all my shared files, but it still won't
show up in my "network".
> > Shri
> > > > name).
> > > > Shri
> > > > > Internet Security.
> > > > > answers.
S
#8
Alogn the lines of what you described, here's something else I did based on
a suggestion in one of the Microsoft Knowledge Base docs titled "Manually
Populating Network Neighborhood with Static Entries for Browsing" (Article ID
210327):
On my Win 98 machine, I did Start-Find-Computers and typed in my Vista
computer name. It did find the computer (no surprise here considering the
successful pings). I then right-clicked the name of the found computer and
created a short-cut in the Network Neighborhood (not sure what the XP
equivalent is). The Vista computer consistently shows up every time I boot
up now, and I can expand it and see the Public and Users folders. However, I
still can't open them (the Win 98 machine locks up).
Also, the Vista computer still does not "see" the Win 98 machine.
The search goes on,,,,,
Shri
"amatie" wrote:
> Partial Success
> > > Shri
> > > > > name).
> > > > > Shri
> > > > > > Internet Security.
> > > > > > answers.
A
amatie
#9
thanks, I'll do that, I can now see all my comp's with any comp byt typing in
the name. If I still had a system with 98 on it, I'd try to help you out --
Sorry not willing to re-install 98SE
> 210327):
> Shri
> "amatie" wrote:
> > Partial Success
> > > > Shri
> > > > > > name).
> > > > > > Shri
> > > > > > > Internet Security.
> > > > > > > answers.
S
sunfish
#10
My 98se and Vista network one way from the Vista side when connected with a
simple hub. No one has been able to network both ways. I think I have been
lucky as the 98se machine was setup with an XP network disk. My XP machine
networks with both 98se and Vista independent of workgroup names or setup of
any kind on the XP. The only difference I can see is the hub (and the XP
setup) as suggested by the Ron discussion.Win98+Vista--possible or not?
> > 210327):
> > Shri
> > "amatie" wrote:
> > > Partial Success
> > > > > Shri
> > > > > > > name).
> > > > > > > Shri
> > > > > > > > Internet Security.
> > > > > > > > answers.
C
Chuck [MVP]
#11
On Tue, 28 Aug 2007 13:24:03 -0700, amatie <amatie@xxxxxx>
>Internet Security.
>answers.
If you're looking for visibility between Windows XP and Vista, and all personal
firewalls are properly setup, then do some diagnostic work. Look at logs from
"browstat status", "ipconfig /all", "net config server", and "net config
workstation", from each computer. Read this article, and linked articles, and
follow instructions precisely (download browstat!):
<http://nitecruzr.blogspot.com/2005/05/troubleshooting-network-neighborhood.html#AskingForHelp>
Cheers,
Chuck, MS-MVP 2005-2007 [Windows - Networking]
Paranoia is not a problem, when it's a normal response from experience.
My email is AT DOT
actual address pchuck mvps org.
