New Hard Drive questions
Slammer
Destroyer of Tyranny
467
Location
New Mexico, USA!
I'm going to be getting a new 1TB hard drive for my laptop, and have some questions about it:
1. Someone told me they didn't think my laptop would support a HD that's 1TB, that I'd have to partition it into smaller sizes. Is this true? Is there any way to tell? I wouldn't mind doing that, but I'd like to know beforehand.
2. I'm going to take my old 320GB laptop hd and use a SATA to USB connector to use it as an external storage device. Since it will still have Vista installed on it (at least until I reformat it) will I be able to boot vista off it through that USB connector? If not, is there any way I could do it through other means? I'd like to use it to experiment with dual booting and partitions (since I've never managed to do either successfully) but I want to do that on a hd other than the one I'll be using in case something goes bad again.
3. I'd like to duplicate the 320 HD I have onto the new 1TB HD, but there's a problem. I know there are several utilities I can use to back up an image of a HD, but I have nowhere to store that backup image. My current HD has about 10GB free, and the SATA to USB connector I'm going to get says it only supports sizes up to 500GB. I was thinking there's a way I could put the new HD into my laptop, then use a Linux Live CD to boot up and plug in the old HD with the USB adapter and use one of those utilities to copy that HD image right onto my new one, but I'm not at all familiar with any of those procedures. A little help would be great :)
4. Is there anything else I should know about doing any of this?
Thanks for your assistance! :)
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB
    Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
americancritic
1,554
Location
Arizona
Hello
Go to your manufacture's website and they will tell you what you can do and tell you what you can't do. Thats what I did and you can even print there instructions. LOL
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
Slammer
467
Location
New Mexico, USA!
You mean the manufacturer of my computer or new HD? Because I'm trying to avoid trawling through Dell's website to find any of this info...
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
Shadowjk
Network Enthusiast
2,180
Location
Northamptonshire, England
For a start I do not know what that person was smoking because you can use a 1TB HDD in Full on any system
Just a question - Do you have a Install Disk?
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Slammer
467
Location
New Mexico, USA!
That was my reaction as well, just wanted to be sure in case they happened to know something weird like that.
Unfortunately I don't. The computer was a gift, only came with an AC cable haha. Although I do have a recovery partition that I know works because I had to use it to restore my comp to factory settings once.
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
Shadowjk
Network Enthusiast
2,180
Location
Okay please be aware of the risks that are involved with replacing a HDD
If your OS dies or has a problem then you cannot use the restore Partition in anyway or form
If you can make some recovery Disks if that option is available
    AMD HD Radeon 6870
    Novatech Night
Slammer
467
Location
New Mexico, USA!
Ok thanks I'll look into recovery discs. Also, it came from Dell and has a sort of "custom" Vista OS (such as Dell Games, Dell DataSafe, and a few things like that configured into it) so would it still be OK to reinstall Vista from a normal Vista disc (like you'd buy at walmart) if I ever needed to? Same question for upgrading to Windows 7. Because if I can't figure out how to copy an image of my HD onto the new one I may just install 7 directly onto it and reinstall all my programs.
If I do clone the HD, wouldn't it still include that recovery partition and basically be the exact same HD, just with 700GB of free space on it?
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
Shadowjk
Network Enthusiast
2,180
Location
#8
It depends on how you go about cloning your HDD - If you image all the partitions including the Restore Partition then it may work but there is a chance it will not
Also No your key will not work with a Normal Windows Vista Disk because your Product key is linked with Dell
Activation works as follows
You enter you product key
It is then converted into a bunch of Numbers and letters
This is then compared to a Certificate (In your Case Dells) which is found during the install (The Reason why you have a recovery Partition)
If it matches the certificate all is good - If not then No
________________________
If you Choose to upgrade to seven then I can help you with the setup and help choose the right edition for you
Josh
    AMD HD Radeon 6870
    Novatech Night
Slammer
467
Location
New Mexico, USA!
#9
Ok well it sounds like it's worth a shot when I do clone it. So wait you mean even if I bought a totally new Vista disc from walmart I couldn't do a clean install of it on my current computer? Like reformat the HD and install it? Or do you mean I just can't restore the OS using a new disc?
Thanks for the offer, I'll let you know if I need any help if/when I do it, but I think I'll be ok. This site has some good tutorials up.
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
Shadowjk
Network Enthusiast
2,180
Location
#10
If you cloned your HDD and transferred it then it would be A-Okay shouldn't need to activate and if you did ring the telephone number for activation
If you brought the disc and installed it you should have the Licence key for that Windows Vista with the Disc and even then you might as well have brought Windows 7
If it didn't have a product key then you may have a trouble activating your Dell OEM Key with a Retail Vista Install
Josh
    AMD HD Radeon 6870
    Novatech Night
Shadowjk
Network Enthusiast
2,180
Location
#11
    AMD HD Radeon 6870
    Novatech Night
richc46
Staff member
20,105
Location
Fairfield County, CT
#12
I would recommend Macrium Reflect - Macrium Reflect FREE Edition - Information and download
How to Reinstall With Macrium Reflect | eHow.com
I would use the Windows Built in Image system but since you have Vista Home Premium that option is not available
You will need to create a disk to be able to restore the image
Josh
May I just add a note to what is already an excellent suggetion. It is merely this, rumours say that Macrium may not stay free, so follow Josh's advice without delay.
Slammer
467
Location
New Mexico, USA!
#13
Ok That's what I thought.
Ya I know I just wanted to make sure that installing a retail version of vista wouldn't mess with my computer. Wasn't sure if it had to have the specialized Dell Vista installed or not.
Ya I'd be sure to get a key for it. But if I ever need to I'll probably just jump up to 7.
I think that's all the help I need for now, I'll come back if I have any more questions, and probably will once I actually get the new HD in and have time to mess around with it. You've been very helpful! Thank you!
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
Slammer
467
Location
New Mexico, USA!
#14
Josh
Thanks rich, I'll check it out right away.
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
Slammer
467
Location
New Mexico, USA!
#15
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
30
Location
Netherlands
#16
just aquick note. Makng your harddrive into an external one would work since u have the os already installed all uave to change is tue boot up order. I thought of doing the same thing but could not install vista on to my external.
    Acer Espire 7730ZG
    Intel Pentium Dual CPU T3400 @2.16GHz
    1T
    GeForce 9300M GS
    C:\
    D:\
    Trust
Shadowjk
Network Enthusiast
2,180
Location
#17
Ok i checked Macrium out, but on cnet EASEUS Todo Backup Free - Free software downloads and software reviews - CNET Downloads is rated higher. Is this one better? I usually trust cnet's reviews and would normally get that one instead, but if you still recommend Macrium I'd trust your judgement over theirs.
I haven't used that before - You could try it but I will be unable to support you since I do not use that Program. Plus I only use EASEUS for a partition manager ;)
Josh
    AMD HD Radeon 6870
    Novatech Night
Slammer
467
Location
New Mexico, USA!
#18
Thanks Boatdude, a quick google search confirmed that I CAN boot off a USB HD like a normal HD as long as you chose it at BIOS. Like you said. Probably should have just googled it to begin with haha.
@Josh Ok well I downloaded them both so when it comes in I'll install both of them and compare the interfaces. EASUS looks likes its directed mainly at simplicity and ease for inexperienced users, so I'll have to see if it has as many features as Macrium, or if I even need other features.
Again, thank you all for your input and help with this, the first time you do something like this is always the hardest because you don't know exactly what to expect, and you guys are really helping me get a feel for doing this in a way google couldn't :)
I'll probably come back here occasionally between now and when it actually comes in (hopefully a couple weeks), but for now I think I'm good!
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
richc46
Staff member
20,105
Location
#19
Most members use Macrium. I would go with Macrium.
Shadowjk
Network Enthusiast
2,180
Location
#20
No Problem - As for me helping you I have to predict what will happen and what problems that might occur and then find a solution :)
Until you have the HDD and have imaged and restored completely I shall not mark this thread as solved
Josh
    AMD HD Radeon 6870
    Novatech Night
