New Realtek HD Audio Drivers (ver. 1.73)
F
Frenchy
"Cal Bear '66" <xxx@xxx.org> wrote in message
news:uIvL0F13HHA.2752@TK2MSFTNGP06.phx.gbl...
> http://www.realtek.com.tw/downloads...=3&GetDown=false#High Definition Audio Codecs
> I Bleed Blue and Gold
> GO BEARS!
Thanks for that update, BUT I have lost my Realtek control panel that used
to sit in the RH Tray. Can't seem to find where it is as a program to put
it back there
Any ideas? The sounds are working though
Frenchy
C
Cal Bear '66
Control Panel (Classic view) > Realtek HD Audio Manager?
GO BEARS!
"Frenchy" <Invalid@invalid.com> wrote in message news:f9voor$c6k$2@aioe.org...
>> GO BEARS!
> it back there
> Frenchy
D
Dave Cox
"Frenchy" <Invalid@invalid.com> wrote in news:f9voor$c6k$2@aioe.org:
>> http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PN
>> id=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false#High%20Def
>> inition%20Audio%20Codecs
>> GO BEARS!
> that used to sit in the RH Tray. Can't seem to find where it is
> as a program to put it back there
> Frenchy
Reinstall the drivers - same thing has happened to me a couple times
with realtek drivers.
The most reliable time to upgrade to a new Operating System is at the
end of its life cycle.
Dave
F
Frenchy
Nope, I looked there first, but it has disappeared from there.
In the location for the unzipped files from the 1.73 download, you can see
the file RtHDVCpl.exe in the Vista Folder within that group, but it does
nothing and doesn't seem to have been installed anywhere in a search.
I liked that Control Panel, an excellent way to check and alter the speakers
Frenchy
news:%23ra1M943HHA.1184@TK2MSFTNGP04.phx.gbl...
> GO BEARS!
>>> GO BEARS!
>> used
>> put
>> it back there
>> Frenchy
F
Frenchy
"Dave Cox" <dcox1961@gmail.com> wrote in message
news:Xns998DA5222BBA5dcoxgmailcom@69.28.186.121...
>>> GO BEARS!
>> Frenchy
> Dave
Umm, I have done that twice already, OK here goes a third. Each time I have
done it with and without elevated Admin privileges and with all Virus stuff
off.
Frenchy
F
Frenchy
news:fa09pt$mig$1@aioe.org...
>>>> GO BEARS!
>>> Frenchy
>> Dave
> have done it with and without elevated Admin privileges and with all Virus
> stuff off.
> Frenchy
GO FIGURE!!! Installed it for the third time and all went well and I have
my control panel back.
Only thing I did different was to empty out the TEMP folder, in case
anything was jammed in there as a partial install.
Thanks your help, hope it helps others
Frenchy
Brink
Staff member
mvp
32,201
Location
Oklahoma, USA
#8
Frenchy
Hi Frenchy,
Yeah, I noticed that I would need to install the Realtek driver from within an Administrator account twice. Once to uninstall the old version and the second time to install the new one. Of course with a restart for each. (haha) Then it runs smooth as can be.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
