New Vista ULTIMATE UPGRADE Will NOT UPGRADE
goldenDragon1
:huh: Hi... Am trying to install AN UPGRADE TO ULTIMATE on a 32 Bit System running Vista Premium & SP2. My brand new UPGRADE is REFUSING to UPGRADE IN PLACE!!! It says "Upgrade has been disabled. The upgrade cannot be started. To upgrade cancel the installation, then choose to upgrade to a version of Windows that is more recent than the version you are currently running". HUH??? This pc is 12 months old & running Windows 6 Home Premium. I am SURE I MADE NO MISTAKES, The Windows Vista Upgrade Advisor has confirmed ULTIMATE for this pc. BOTH Anti-Virus Programs were disabled...etc. BECAUSE I could NOT INSTALL, I am NOT ELIGIBLE for the FREE 90 Day Support Feature... This is a BRAND NEW SOFTWARE PURCHASE & WAS EXPENSIVE... I HOPE SOMEONE AT WINDOWS CAN HELP ME WITH THIS PROBLEM... Thank-You :sarc: p.s. {I do not know if the "Clean Install" works or not... ONLY THAT THE UPGRADE INSTALL WILL NOT... I NEED the UPGRADE INSTALLATION, & according to the package & all other data- MY PC IS ELIGIBLE TO THE UPGRADE... So I am very concerned- to say the least}. . . :cry:
stoneys-nutz
Gamerholic
Hello goldenDragon1,
The best way to install any Windows is a clean install, i would backup all the bits i want to keep to another HDD or disk and do a clean install, there is less chance of encountering any errors. The reason you cant "upgrade" could be because the Ultimate disk, although a better version of Vista, is an older copy than the one it's trying to replace. Hope this helps. Good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
